Front door panel removal help!
Old Dec 25, 2006 | 01:25 PM
CAMARO16's Avatar
I just got some kicker speakers and i need to take my side door panel off. I got all the screws taken out but its attatched on somehow in the middle. Is it something to do with the handle? I have a camaro book that shows how to do everything but i cant find it so i was wondering if any of you knew how so i can get my new speakers in. Thankls
Old Dec 25, 2006 | 02:17 PM
2001NBMZ28's Avatar
Probably forgot a screw somewhere - take a look at shoebox's window motor replacement guide on how to take the door panels off. http://shbox.com/page/windowmotor.html
Old Dec 25, 2006 | 04:43 PM
CAMARO16's Avatar
Thanks alot thats exactly the info i needed. I did forget a few screws but have all of them out now for sure. I just need to know how to unplug the window buttons and take the lock switch out and it shows on the link you posted. Thanks alot tomorrow morning i should have my kicker speakers in
Old Dec 25, 2006 | 05:04 PM
01Z's Avatar
01Z
You can remove the door panel without unplugging the switches by turning the switch around until it feeds back down the hole but if you want to remove the switch from the wiring it simply pulls (or pries) from the wire loom gang plug. A small flat blade worked around the edges will do it but be careful to not short across the pins.
cmyname1
Feb 19, 2015 08:38 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
MilkyClr69
Jul 29, 2002 10:01 AM
Zomie
Jul 25, 2002 07:52 AM
