Found SUB now which AMP??
Old Apr 18, 2003 | 01:39 PM
DarkzSS's Avatar
I've decided on 2 Diamond Audio 10" TDXD2's. It says they have a depth of 8.9 inches. These are big subs by any chance would these fit in a pair of subthump's stealth box with no problems?
I hear these subs take a lot of power, what would be a sufficient amp to go to these two subs? OHM ratings, etc.?
Any good online places to check pricing besides crutchfield?
TIA
Old Apr 19, 2003 | 01:46 AM
DarkzSS's Avatar
anyone? ive been looking into a cheaper alternative also, How do the JL w3's and w6's compare to each other and the diamond's? Will i notice a difference between the w3's to 6's? and where is the cheapest place to find these ?
tia
Old Apr 19, 2003 | 02:21 PM
firebirdude's Avatar
Ebay is the cheapest place to find anything. If you get the dual 2 ohm version, you will want to wire the voice coils together in series and then the subs together in parallel. Final impedence will be 2 ohms. If you get the dual 4 ohm verison, you will want to wire the voice coils in parallel and then the subs together in parallel. Final impedence will be 1 ohm. If you go that route, make sure your amp is 1 ohm stable. JBL BP1200.1 can be had off ebay for $275 and outputs over 1200WRMS and is stable to 1 ohm....
Old Apr 19, 2003 | 08:13 PM
archemedes's Avatar
if your thinking of jl, get eclipse, they are the exact same speaker, for less money, as far as amps, get the most power you can afford
Old Apr 20, 2003 | 12:40 AM
rthompson's Avatar
I hope you are kidding, or else you are misinformed......
Old Apr 20, 2003 | 09:47 AM
archemedes's Avatar
I am not kidding and am not misinformed, there are only 4 speaker manufacturers in the world today, and the only one any of you probably know is rockford fosgate, most of the car audio companies get theirs from either rockford or a european company called eminence, I was doing some demo cars for eclipse and had to order from the supplier, they are the ones that let me know
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
meissen
Aug 11, 2015 06:05 AM
jackpawt883
Jul 31, 2015 08:15 AM
Boss002
Jul 9, 2015 03:33 PM
