Factory bose questions
Hey everybody, how is the factory bose 5 speaker system set up in a 95z? Is it full range in the doors, lows in the pillars beside the back seats and lows in the factory sub on drivers side rear? The reason I ask is that I have full range sound coming from the sub and only lows coming from the pillars. When I bought the car the sub was unhooked and the factory speakers in the pillars were replaced with bazooka 6.5" which have no sound coming from the tweeters. I know the factory 6.5 were 2 ohm but would a higher ohm speaker limit the range of sound? Also is the sub supposed to be full range?
Thanks in advance,
Peyton
Thanks in advance,
Peyton
I have the same year car/system. I am nor sure what the impedence is for the factory (you said 2ohms') but I tried to put a JBL Midrange up front and there was barely any sound coming from them. That would explain going from a 2ohm speaker to a 4 ohm speaker. Im pretty sure the rear 6.5" "woofer" has a pretty weak crossover point and slope becaue it does seem to play all ranges. I bet its tuned by BOSE to work in the 100 to 300hz range were al lot of audible base is, in-lieu of 80hz down where you can "feel" base. Im sorry im just rambling here and havent really answered any of your questions........
u2slo5point0
Sep 9, 2002 05:44 PM
