Distortion in subs with deck turn on and off
Old Mar 20, 2006 | 09:41 PM
danny525's Avatar
Question Distortion in subs with deck turn on and off
There is like a little popping from the subs when the deck turns on and off. I know its not the deck 100%, do you guys think its a bad ground? Where do yuo all ground out your amps?
Old Mar 20, 2006 | 10:22 PM
imthe420dan's Avatar
Re: Distortion in subs with deck turn on and off
You should be able to ground any where on the vehicle as long as there is absolutely no paint between the connection. I had a similar problem and it was my ground also...Also make sure that you dont have positive and negative switched on each sub, like one sub has a positive lead on the positive and the other sub has the positive on the negative lead this could cause some popping and similar sounds...
Old Mar 21, 2006 | 12:20 AM
danny525's Avatar
A new syptom, i think i car almost hear my engine in my sub! Put it this way, it made my car sound much beefier, i was wondering what the hell, then i realized it was coming from my subs!
Old Mar 21, 2006 | 04:57 PM
wakebordr2006's Avatar
its not your ground, i had the exact same problem in my camaro. i could hear my exhaust through my subs, it sounded pretty funny. its your RCA cables that connect to the back of your cd deck. the camaro has little space when the head unit is slid all the back and the RCA's eventually crimp up causing poping and engine noise. so you should just pull out your head unit and unplug the RCA's and replug them back in making sure they are straight and you should be fine. also make sure you dont have to much slack back there.
Old Mar 22, 2006 | 05:47 PM
change the fuse
Old Mar 22, 2006 | 07:32 PM
lastZ's Avatar
cahnge the fuse? what the hell does that have to do with it? wakebordr2006 has the right idea...its akll in the rca cables and grounding
Old Mar 23, 2006 | 07:32 AM
Ill tell you what change the fuse can do... Some fuses wont blow all the way or they wont blow to where you can see the blown part of the fuse, making you think its still a good fuse. amp still powers up but now it is all distorted from lack of voltage. I gaurantee it. Im not saying that all the other suggestions are wrong just that this is a possibility.
Old Mar 23, 2006 | 09:03 AM
Digital Designs's Avatar
your problem is a ground loop. re-ground the amp with the shortest length possible, run your RCA's on the opposite side of the vehicle that the amp power runs. this should eliminate it.
Old Mar 23, 2006 | 02:16 PM
Let us know what happened and what problem you found
Old Mar 25, 2006 | 01:57 AM
danny525's Avatar
im gonna figure it out tommarow, gonna start with the ground, then run some new rca's and ill even try the fuse! ill let you all know.
Old Mar 25, 2006 | 11:24 AM
you dont need to run new RCA's. they are just kinked where it connects to the hu. just unkink them. thats all you have to do. i can gurantee it!!
Old Mar 26, 2006 | 12:54 AM
danny525's Avatar
well your garantee means ****all lol cause it was the rcas, i pulled the deck out, made sure there was no kinks, still the same, ran a new set and presto! no more problem, so ya it was the rca's, not the ground, or any kinks- it was the wires ( and they were stinger wires, so much for name brands) And i know the wires were no good cause after pulling them out, i tested them in unran and the problem still exsited. Thanks for all your help.
Old Mar 26, 2006 | 08:18 AM
oh ok, well you must of had some cheap rca's cause i've got rockford fosgate and all i had to do was unkink them and it worked as good as new. did you have the rca's running on the same side as the power wire?
Old Mar 26, 2006 | 08:48 AM
LS1 RULZ's Avatar
If you had a kink in them then the wire inside has probably broken. Straightening out the kink has more than likely restored the connection between the wires. Chances are, over time, you'll develop an intermittent connection problem with the signal cutting in and out. If you do you'll know where to look first to fix the problem.
Old Mar 26, 2006 | 09:26 AM
Angelis83LT's Avatar
That was an intreesteing read lol.. The problem was pretty apparent as soon as he said he could hear his exaust in his subs or whatever lol.. All it was was poorly shielded RCA cables that were picking up on the magnetic field created by the electronics in the car. (electricity of any kind created a field around it, with an unshielded wire connected to a speaker or amp, it will be affected by the field creating a humming or popping noise (huming when the car is running, and poping on shut off and turn on.) the humming also can go up or down depending on the RPM of the car, since most times.. the magnetic field that is affectinct it is coming off the coil or another large power source of the like..)
