Crackling in the tweeters, components
Old Mar 1, 2007 | 09:00 PM
ReNxWar's Avatar
I'm having issues with my new cars speakers.. its got a component setup (apline, I believe) I'm not sure where the crossovers are, but I do know it had the Monsoon system.. the components were re-wired to the headunit.
I'm using the Pioneer P960MP headunit, and the components are being powered off it (I know, not perfect.. but its a good temporary solution.)
Anyway, the problem is on certain (in fact, most) songs, the tweeters crackle. I've tried rewiring the headunit harness, switching the pos and neg in case I got them backwards, etc.. nothing fixed the crackle. I don't know where the crossovers are, so I can't adjust anything there. Hopefully theres something simple I'm missing, or something not quite configured right. Thanks in advance.
Old Mar 1, 2007 | 09:10 PM
fredmr39's Avatar
Incorrect.
The crossovers are not in line, or anything like that -- but is actually nothing more than the capacitor at the front stock tweeter components. The only line that does not get a full signal is the woofers in the sails -- the amp passes through them through a LPF - but other than that, all filtering is done at the speakers.
Old Mar 1, 2007 | 09:13 PM
fredmr39's Avatar
To fix this....you can integrate the crossover into your setup, or look at your old tweeter, find the capacitor (observing exactly how it is mounted) and include that in the ckt. with your new tweeter.
Old Mar 1, 2007 | 09:15 PM
ReNxWar's Avatar
Originally Posted by fredmr39
Incorrect.
Alright, so what kind of troubleshooting can I do for the crackling?
Old Mar 1, 2007 | 09:35 PM
fredmr39's Avatar
I would wire it up properly first and see where you're at then.
Old Mar 2, 2007 | 03:31 PM
valter's Avatar
If your components wired directly to headunit you will never get a good sound, as HU output well below recommended for components. To try fix problem - locate crossovers, check whether they are not damaged/connected correctly (I've seen "installs" when tweeters were wired in parallel to midranges without crossover lol). If everything fine, you tweeters probably blown.
Old Mar 5, 2007 | 02:48 PM
78Z28350's Avatar
my home stereo does the same thing for some reason. i noticed it does it when i stand in a certain position in my room and it is playing a cd not static from radio. i been lost about it for a while but it only happens when i leave it on for a long time.
HibachiZ28
Nov 6, 2015 12:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
karpetcm
Aug 14, 2015 03:02 PM
Brian Demeter
Aug 21, 2002 02:07 PM
