couple of speaker size Q's
I am in the process of upgrading my car stereo and first thing I'm doing is getting rid of all the factory speakers and replacing them. Anyway I was over at best buy and they had a computer and all the replacements were 6 1/2 inches, aren't these 5 1/4 inch? Also what brand should I get? The other thing I was wondering about are the rear speakers, they look like 6 by 9s but when I pulled off the cover was only a 4 and a tweeter! question is with some trimming could I pull these out and put in some 6by9s, also what kind should I replace these with. Sorry for the lame questions I'm a newbie when it comes to stereos.
Thanks brad
Lingenfelter cai, march ud pulleys, Maf!, TB!, 94-95 pacesetter 1 5/8 shorties, custom off road s-pipe, slp 2ol, MW 2800 stall, Bmr lcas
No times yet but shootin for a high 12 on Drag radials.
Thanks brad
other else than the trunk speakers, they are 6 1/2 all around. Actually, oversized 6 1/2. As for the rear speakers, more people would say don't put any in the back and just use a front stage (component) which is a good idea if you are going with a normal audio setup for your car. I have rear speakers on mine for my DVD player so my setup is an exception. For what brand, that's really subjective. You'll have to start to demo different speakers and see what you like (I wouid like to suggest Focals
) And as mentioned before, I would not worry about the rear speakers, but if you do, I would not do the 6 x 9 in the back. If you are bent on getting it, I'd stick with the same speaker size and just get a 4" two way.
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
) And as mentioned before, I would not worry about the rear speakers, but if you do, I would not do the 6 x 9 in the back. If you are bent on getting it, I'd stick with the same speaker size and just get a 4" two way.------------------
Audio/Video:
My SS homepage
CAR AUDIO PLANET
A 6x9 is too much speaker for that flimsy *** plastic panel you have to mount it to. There isn't enough mass there to properly support the speaker and to handle all the vibrations caused by the much larger woofer. But if thats what you want to do knock yourself out.
Yea they are definitely oversized 6.5's all around(roughly 6.75 i believe) and i have MB Quart's in my car and they sound amazing. I would definitely suggest going either with a set of MB Quarts or Focals. IMO those are the best two speakers out there.
OH, and make sure you use an amp to power them, they sound 110% better than running off of the minimal power that the deck puts out. They will be much louder and "cleaner" if you run them from a 4 channel amp
1994 Teal Z28
Cowl Induction Hood
Hurst Short Throw
Edelbrock Headers
Adjustable Borla Cat-Back
SLP CAI
17" Eagle wheels w/245 45 17 Kuhmo Supras
TB Bypass
Air Foil
160 degree thermostat
1LE High flow bellows
13.75@102.13mph
AIM name: kristof30
My 94Z
1994 Teal Z28
Cowl Induction Hood
Hurst Short Throw
Edelbrock Headers
SLP CAI
TB Bypass
Air Foil
13.75@102.13mph
AIM name: kristof30
My 94Z
<font face="Verdana, Arial" size="2">Originally posted by Brad 97z:
Like I said I'm a newbie to stereos. I don't now squat. How do I go about wiring in an amp to power my speakers?</font>
LS1 RULZ
Aug 11, 2002 11:15 PM
