Cigarette Lighter fuse blows
Old Jun 1, 2010 | 09:22 PM
PewterZ's Avatar
Unhappy Cigarette Lighter fuse blows
I've been tapping into the cig lighter to power my Sirius Satellite Radio receiver. After more than a year of flawless use, it now blows the fuse as soon as the ignition is turned on. Where do you suppose is this obvious short?
Steve
1999 Pewter Z28
Ported T/B, SLP intake system, Magnaflow cat-back, shock tower brace.
Old Jun 2, 2010 | 08:36 AM
Chevyssoccer's Avatar
I would obviously start where you are tapped in to it. Arent the fbody lighters constant power though, and not switched?
Old Jul 6, 2010 | 09:14 PM
kd5icr's Avatar
Yes the plugs are a constant. And like the post above me said check were you taped it.
You may want to try to find power on the fuse block there are sometimes a empty slot that says battery or something like that. and run power from that. just use a in line fuse rated at what ever the recever calls for. That way if the sat radio does go out you can find the problem a little faster.
Also if you have kids you may want to look into the lighter itself, mine did put a dime down in it, and I blew 4 fuses before I looked and saw it.It realy isnt a good idea to run power like that, it could cause the main lighter wire to over heat and could start a fire.This is all just my opinion but that is how I run my XM set, and have not had a problem one.
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 08:50 AM
z28newbie
Sep 9, 2015 10:26 AM
