Big time battery issues
Old Feb 11, 2008 | 08:49 PM
eagleknight97's Avatar
If I dont start my car for 2 days or more, the battery is dead. Initially I thought this was due to the system I had installed in my car last year, but the problem didnt pop up until a few months ago. About 3 weeks ago I took all my stereo stuff out and put a new battery in and I am still having the problem, so that rules out the system. Alternator SHOULD be ok, I had it tested when this problem started and they said it was ok. However I suppose I dont necessarily believe them. What are some other areas I can check or should I just get a new alternator?
Im unable to check anything out personally right now, as im at school with my truck and my car is at home with my dad.
Old Feb 11, 2008 | 09:35 PM
Eric H's Avatar
I doubt the alternator is the culprit if the problem only occurs when the car has been sitting for days.
It sounds like you have a drain on the electrical system that is slowly draining your battery. When you drive the car the alternator charges the battery back up... But if the car sits, the battery drains.
Unfortunately, these problems can be difficult to isolate. I'd start by confirming all lights, accessories, amps, etc. are turned off when the vehicle is sitting.
Old Feb 13, 2008 | 01:14 AM
bighash007's Avatar
i have the same problem i have huge system in my car as well..i changed out battery and alternator. I posted a thread about it and alot of people believe it is an electrical problem check to see if you have a short somewhere
Old Feb 13, 2008 | 12:59 PM
fredmr39's Avatar
Start by eliminating the fact that this could be caused by a drain w/ the car off.
Use a multimeter to measure current with the car off. If it is high (greater than 50mA....probably should be under 30mA) then start pulling fuses until you isolate the circuit with the drain. Then further examine that circuit (especially anything you've ever touched). If you ever bring your car down here let me know.
Old Feb 13, 2008 | 05:16 PM
Where do i check the overall current with the car off? Ive never really done anything truly electrical with the car, just some basic audio stuff.
Old Feb 14, 2008 | 10:06 PM
fredmr39's Avatar
In series with the battery (between negative batt. post and negative batt. wire)...... only measure with the car OFF
Gtpguy
Jan 26, 2015 04:50 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Louey
Pacific
Nov 28, 2014 03:46 AM
Snoman73
Nov 17, 2014 07:22 PM
