Bassy 6x9"s needed
Bassy 6x9"s needed
My system is lacking punch but I don't want to install a sub for space reasons. I listen to rock and don't want thumping bass like alot of people who listen to rock want (not that there is anything wrong with that, its just not for me). I have pioneer's in the rear and I like them, but once again, no bass. What are the best 6x9"s to get if I want some more low end?
Re: Bassy 6x9"s needed
The curse of the 3rd gens is that those sail panels cannot produce anything approaching decent bass. Type of 6x9 will make NO difference
What I do to get some bass is record my MP3s (or CDs) through the SRS Wow Thing! in WinAmp 2.9x and then to a folder on my hard drive. Then I record the files to CD, whether MP3 or wave.
This gives me very satisfying bass for an accurate reproduction of rock, which I prefer too
It is a bit of a procedure to accomplish and you MUST have a CD burner to accomplish this. If you do, then send me an email tsauve@shaw.ca and I will send you two files of the same song, one processed through SRS and the other not. Then you can decide if you want to do it.
Josh,
I have a 3rd gen car club meeting tonight but will get back to you shortly. In the meantime, go to the WinAmp site and get the SRS WowThing! and the Lame MP3 plugin from their Plug In section.
OK, here we go
For those who would like to actually hear what this SRS system does for your music, here is the download page. It works as a plug-in for WinAmp (Windows MediaPlayer 9 also has it built in):
http://www.winamp.com/plugins/details.php?id=1724
If you are clever you can even run it through your home stereo, or print an output file to MP3 or Wave on your hard drive and then record it to CD and play it on any CD player you have, including the car player. It sounds awesome in the car
PS Here are the activation codes. You MUST type them in (won't work if you cut and paste) EXACTLY as shown here. DO NOT use your own email address but rather type the wow@wowthing.com address!
EMail Address: wow@wowthing.com
Registration Key: Severe stray hosts broil likely junior folks randomly
Next, you must activate it as the DSP/Effect Plugin of choice. Go to WinAmp's Options>Preferences>Plugins>DSP/Effect and highlight the SRS Wow! Processing for WinAmp.
Then you must turn it on. When the program is on on the desktop there are 3 buttons on both the left and right side. The top right one is the On/Off button. The buttons on the left let you choose your speaker type or headphones. The curved sliders on the top and bottom allow you to increase the bass (bottom) or increase the surround effect (top).
When you right click on the program it allows you to Minimize the program to the system tray.
Go to the end of this thread for a picture of how it should look when activated and turned on. http://www.thirdgen.org/techbb2/show...hreadid=242405
When you get it up and running correctly we'll move to the next step.
I did everything you said and it still cuts the volume quite a bit when I activate it.
Are you sure that the volume doesn't go down when you turn it off? It will work correctly when it is setup right.
When I click "off" the volume is the same, but when I bypass the plugin the volume increases drastically. I am just using the stock EQ right now and it made a large difference. I'm gonna stuff that compartment becuase that makes perfect sense and is abslutely right. Thanks guys.
