Attn: Anyone looking to upgrade or replace Monsoon Speakers!
Old Nov 6, 2003 | 09:25 PM
  #16
ChickenScreamer94's Avatar
could this setup work on a 94 car? Since the sub is three ohm cant wont you have more power since it is two ohm load or am i backwards here? I believe the fronts are four ohm....
HOw much was relatively cheap? Like under 200?
Old Nov 6, 2003 | 10:42 PM
  #17
Rogue Leader's Avatar
The bose setup is completely different, and IMHO that setup I reccomend replacing it all... My sister has it in her 94 Camaro and no matter what you do it sounds like complete ***...
Old Nov 7, 2003 | 05:18 PM
  #18
No, no, i have a ten speaker setup very similar to the monsoon, the 93-96 birds had this, and camaros had bose three or five speaker. It is four ohm fronts, and three ohm rear speaker rating or whatever (it say 3 ohm on back of speaker). SO can i use the RF sub back there and have similar results?
Old Nov 7, 2003 | 06:06 PM
  #19
Honestly I guess it could work... but 3 ohms could theoretically not work properly... I really just dont know...
Old Nov 8, 2003 | 01:33 PM
  #20
........and the 2 ohm experiment
I figured Id see what happens if I wire the new tweeters in parallel with the door speakers to get a 2 Ohm load. Well Aparently the amp may also have a mid pass filter on the door speakers cause some frequencies seemed cut and it sounded worse... So much for that one oh well. Just hook the tweeters to the factory outputs..
Old Nov 17, 2003 | 04:38 PM
  #21
LT4Firehawk's Avatar
The Firebird 10 speaker system can run 4 ohm 6.5S subs without a problem. I used Kicker 4 ohm 6.5" subs in my 95 Formula without any problems.
One question for you guys with these subs, do you loose anything by only using one pair of the leads? I wouldn't think so, but just wondering. Also, another option on subs is the Image Dynamics 6.5 mid bass
http://www.imagedynamicsusa.com/webs...s/midbass.html
which is available in a 2 ohm version. They actually have a wider range and higher sensitivity than the Fosgates, but are a little more expensive. I'm probably gonig to put some of these in my Firehawk this winter. They also make 2 ohm seperates that should fit the fronts as well.
Old Nov 17, 2003 | 05:44 PM
  #22
CSPCamaro's Avatar
I have a 2000 camaro convertible I think it only has four speakers (no subs). Anyone know exactly how the convertibles are set up speaker wise? Any recomendations on speakers cause that is all i want to replace. Thanks!
Old Nov 17, 2003 | 10:04 PM
  #23
Im very interested to hear how these turn out. I would assume the Monsoon Amp doesnt have the juice, but hey you never know... Let us know your findings!!
Old Nov 17, 2003 | 10:05 PM
  #24
If it only has 4 speakers Id assume your car doesnt have a monsoon system.... correct?
Old Nov 18, 2003 | 12:22 AM
  #25
CSPCamaro's Avatar
no its definitely a monsoon system. The convertibles dont have the far rear speakers they just have the two door and the two in the back. I think that they count it as eight speakers because GM considers each individual driver a speaker. (4 tweeters and 4 woofers?) anyone have any suggestions for a convertible?
Old Nov 18, 2003 | 06:27 PM
  #26
Id pull the woffers out in the back and find out the size of them, where are the tweeters mounted?? take pics if you can...
Old Nov 19, 2003 | 01:06 AM
  #27
CSPCamaro's Avatar
They are 6.5'' in the back and in the front. By the way i have some 6.5'' infinity kappa series component speakers that i had in my firebird but that was with an aftermarket system. How do you think they would sound with the monsoon system if I put those in the front. What should i use for the rear fill? appreciate any opinons!
Old Jul 29, 2004 | 01:37 PM
  #28
BlueRave's Avatar
Re: Attn: Anyone looking to upgrade or replace Monsoon Speakers!
Has anyone sucessfully updgraded the speakers on a Convertible camaro with the monsoon system? What speakers did you use? Did you run into any problems?
Old Feb 10, 2005 | 08:59 AM
  #29
BlueRave's Avatar
TTT -- Please see post above. Thanks!
Old Nov 17, 2005 | 12:28 PM
  #30
heliskiier1's Avatar
TTT again...no one can seem to give a good answer on the Convertibles where we don't wanna replace the head unit and amp. HELP!!!!!!
Jazsun
Dec 29, 2014 12:14 PM
Brian-94TA
Jul 31, 2002 02:52 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Chrisdude
Jul 24, 2002 02:25 PM
