amp turn on wire
Old Jan 5, 2005 | 07:45 PM
badassls1z's Avatar
amp turn on wire
i have the stock monsoon headunit in my 99 z28, im hooking up two subs with an amp and i have bought a high to low converter to hook up the rca wiresand i have everything hooked up but the amp turn on wire, is there one on the back of the headunit or how do i need to do this
Old Jan 5, 2005 | 08:21 PM
firebirdude's Avatar
Re: amp turn on wire
You can tap an iginition wire somewhere or off of the power antenna. Firebirds are easy enough because the radios already have a remote turn on. Just tap into the pink wire. Camaro radios also have a remote turn on but there is not a wire coming out of the radio for it. Get a connector to fit the radio harness (available from most auto parts stores) and plug your wire into pin #8. This is your remote turn on.
Old Jan 6, 2005 | 11:23 AM
shouldaboughtthez's Avatar
You can get the connector from Radio shack, it is called a D-Sub female, you can use either a 9pin or 25 pin. They use the same connectors you will just have extra $3 or less. Home Depot has the wire, I used 16 gauge blue wire, comes in a roll of 20' $2.50.
You will have to put the connector on the wire and plug the connector into the #8 hole in the harness behind the radio. Then run the wire to the back.
Jul 4, 2005 05:00 PM
Krab
Aug 5, 2002 12:08 AM
BOOGER
Jul 25, 2002 02:42 PM
Zomie
Jul 21, 2002 08:03 PM
