Amp(s) install question
Old Jun 21, 2008 | 06:44 PM
thegift1's Avatar
Question Amp(s) install question
Im adding a second amp to my system in my 94 firebird and relocating the wiring that from the old setup (the previous setup had the power cable running from the trunk, alongside the driver seat thru the firewall, across the engine to the battery on the passenger side). I'm replacing the power cable but ive run into a problem. The new power cable is not long enough to come from the driver side so obviously i will need to run the cable along the passenger side, but i dont know exactly where I should drill thru the firewall to get into the engine bay. So my question is where should I place the hole?
Old Jun 21, 2008 | 10:08 PM
Blue89Bird's Avatar
don't drill anything, unbolt the ECM, run it through the grommet
Old Jun 22, 2008 | 04:36 PM
midnightnavyz28's Avatar
\thats what i did....two bolts hold the ECM together....just punch a hole in the rubber grommet and send it thru
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
Jul 4, 2005 05:00 PM
Snake Slayer
Jul 29, 2002 12:39 PM
Chrisdude
Jul 24, 2002 02:25 PM
