Amp ?
Old Apr 12, 2006 | 04:25 PM
jsviking08's Avatar
Amp ?
i am new to the camaro family and i have a feeling I will be here a long time cause I am really liking my 95.
I am going to wire up 2 12" MTX subs with a 800 watt 2channel amp. I have a stock Bose sound system already in it. Wat is the best way to wire up the subs? and what is 2ohms and 4 ohms, wat is the difference between the two?
Thanks Josh
Old Apr 13, 2006 | 06:26 AM
LS1 RULZ's Avatar
Re: Amp ?
The best way is to get rid of all the Bose crap and replace it with higher quality after-market equipment.
An ohm is a unit of resistance to the flow of current. The lower the number the higher the amount of current. So a 2 ohm speaker will draw twice as much current as a 4 ohm speaker. If the number of ohms is too low for the amp to produce enough current it will overheat and go into thermal protection mode and shut down.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Bobczar
Oct 23, 2015 11:22 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
