Alarm systems... List of demands
Originally posted by BMC95TA
I don't know about 5 city blocks im not getting anything near that. I'm not using the remote start harness either (M6), and you still have to hook up to the ignition wires off the main brain harness (pinki wire i think) or the alarm doesnt reset itself. Then as far as the sock sensor and proximity sensor I'll have to let you guys know how it works out.
Now that I have taken a closer look at things I see that you're half right. There is no switched ignition wire in the primary harness. That means the alarm gets it's switched input from the pink wire in the relay pack. But since this wire is normally connected to the yellow wire (when the relay's coil isn't energized) in the remote start ribbon cable all you have to do is cut off the ribbon cable and connect the yellow wire to the ignition wire if you don't want to use remote start.
Got the alarm installed on friday. Install went good, just like any other. I didn't use the remote start so it wasn't too bad.
So far kinda dissapointed with the range. Will do more testing this week but it looks like if I decide to get a 2-way pager I will go with a compustar 2WSSA for my car.
CARiD
Jul 7, 2015 08:19 AM
ChrisFrez
Mar 17, 2015 07:31 AM
