alarm system for a convertable
Old Jun 17, 2003 | 11:36 PM
Ciaccia23's Avatar
anyone know of any good alarm systems for convertable camaro, its a 94 Z28 and I am really proud of it and want to protect my investment, but as I do more things to the car I'd like to protect it so let me know what a good one is, I want the alarm to work when the top is down, like maybe sensors so when someone reaches in it goes off or something
thanx in advance
Ciaccia
Old Jun 20, 2003 | 01:19 AM
PaulN64's Avatar
Viper would be a good choice, or anything from DEI. I would suggest having a field alarm sensor. For DEI, it's the 501d. I've got one on my hard top and all you have to do is come close to the car and the warning beeps goes off. It'll work even better on a vert with the top down b/c that is what this is made for.
Old Jun 22, 2003 | 07:45 PM
Ciaccia23's Avatar
hey thanx for the reply man
one question though, which alarm is the 501d I looked at a bunch of alarms and I can't find any with field alarm sensors so maybe could you let me know??? thanx
chacha
Old Jun 22, 2003 | 07:47 PM
PaulN64's Avatar
that's from Viper. That's what I have on my car
Old Jun 22, 2003 | 09:01 PM
cckrocks's Avatar
Field disturbance sensor (radar sensor) part number is 508D. I would recommend the 690vx alarm if you have a manual transmission and the 790vx (same thing with remote start) if you have an automatic. They both have a 2-way remote with a built in pager. Price should be about $599 installed for the 790vx and $499 installed for the 690vx. The radar sensor price will probably vary depending on the shop. Some places don't mind installing them, some hate it. As an average add $200 to the price. I would recommend having a professional shop install it unless you are REALLY CONFIDENT in your wiring abilities. If you decide to tackle it yourself, here's the wiring for the car.
12volts red + ignition harness
Starter yellow + ignition harness
Ignition pink + ignition harness
Power Lock 5wi
Notes: Non-keyless versions: Use light blue for lock and dark blue for unlock. Both wires are located in either door harness. The passenger switch is the master switch. Keyless versions: Use red/black for lock and orange/black for unlock. Both wires are located in the passengers kick panel at the keyless entry module. Do NOT use the orange power wire at the keyless module or door lock switch to power your door lock relays. The passenger switch is the master switch.
Power Unlock 5wi
Lock Motor gray keyless entry module
Notes: The keyless entry module is located in the passengers kick panel.
Unlock Motor tan keyless entry module
Disarm Defeat tan keyless entry module
Parking Lights+ brown drivers kick panel
Parking Lights- none
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger gray - behind left rear speaker
Notes: You can also use gray/black in drivers kick panel on some models.
Dome Supervision none
Trunk/Hatch Pin tied in with door
Hood Pin none
Trunk/Hatch Release black/white + low in the passengers kick
Power Sliding Door
Factory Alarm Arm none
Factory Alarm Disarm none
Disarm No Unlock none
Tachometer white or red/black ac coil/dist. assembly
Notes: White-V6, red/black-V8. Location is front of left cylinder head for V6 and at a 4 pin plug at the passenger side valve cover for the V8.
Horn Trigger black - black conn. st. column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer By Pass: Required: Yes Type: VATS Part #: 652T resistor pack
Old Jul 1, 2003 | 10:50 AM
Dave99Z's Avatar
This ticks me off...
The DEI website lists the 508D at $87. I called a local Dist and they want $125 just for the part????
I guess they really want me to either let them install it, or buy it somewhere else...
Oh, Nice site... Hate to make my first post here with a mad face... LOL!
Old Jul 1, 2003 | 06:17 PM
NineSevenWS6's Avatar
What they said. DEI is definatly the way to go. Im personally partial to Clifford. Just browse the site and see which model/brand fits youre needs. They are all built extremly well, and if an authorized shop sold/installed it, you have limited lifetime warranties on both the unit and the installation. You cant go wrong there.
Heathen1
Jan 2, 2016 04:27 PM
ChrisFrez
Feb 15, 2015 07:49 AM
peptide
Aug 27, 2002 11:26 AM
Eric H
Aug 10, 2002 06:39 AM
dreamer1q
Jul 24, 2002 04:39 PM
