aftermarket raido an bose system
Old Jan 13, 2010 | 11:00 PM
ss1996camaro's Avatar
is there any way to make a aftermarket raido work with the bose system ?
an all the speakers work as they should ? some sort of adapter or some thing ?
Old Jan 15, 2010 | 02:56 PM
The Captain's Avatar
I dont remember exactly how I did it, but it DOES work. If I remember correctly, you have to do something with a pink wire. Do a search for bose and pink and see what comes up. I didnt buy any kind of adapter or anything either.
Old Jan 27, 2010 | 07:45 PM
94arcticwhiteM6's Avatar
on mine there was a blue amp wire that i left disconnected, am/fm worked fine but nothing on cd. hooked up that wire and everything works, but volume level at 5 is like what it used to be almost all the way up on the stock radio.
Old Jan 30, 2010 | 01:53 PM
Venomous360's Avatar
Yes, I,m about to do the same thing, I dont feel like using NEW speakers and running all new wire. There is some power wire that you have to hook up to power the individual Amps on the speakers. It was Pink or Orange or something like that.
Old Jan 30, 2010 | 07:41 PM
96 Z 28's Avatar
Well as far as I know the issue is that each speaker is amped separately. There may be a wire that you can cut to kill all the amps, but that may cut the sound completely.
I've never ever heard of any other solution than to run new wires to each speaker...
That's why I dumped the entire system for new speakers and amps in the trunk
Old Jan 30, 2010 | 09:33 PM
moparman's Avatar
There is an interface available that allows aftermarket head units to work with the Bose.
Old Feb 1, 2010 | 01:53 PM
ImNraged's Avatar
You need a Scosche OEA-4 Factory Amp Interface. It's what's in my car and it works like a champ. If you want to retain the factory wiring (I'm assuming you do), there's a wiring harness that plugs right into your existing wiring. I don't have the model number for that but you can get it almost anywhere. Below is a link to the interface. It's an Amazon link, but you can do an internet search and get it from other places.
http://www.amazon.com/Scosche-4-Chan.../dp/B00009UHSO
Old Feb 6, 2010 | 07:37 PM
z275plus's Avatar
Crutchfield sell an adapter that will plug right up and it will work without any problems.
Old Feb 27, 2010 | 10:26 AM
unvc92camarors's Avatar
I second this. Pretty easy actually on Crutchfield.
Select the stereo you want and put in what car you have and it'll be under "Installation Details" on the selected stereo page. Half off if you buy a receiver over 129 so the $40 adapter becomes $20. Not bad.
I think I might just do this soon for the Z28. I really would like to replace the stock system without having to redo all the speakers and wiring. Plus, having the ability to plug the phone or just USB stick into the stereo would be great. Much better than using CDs or trying to find a crappy station here.
Old May 7, 2010 | 07:57 PM
Z28camaro94454's Avatar
ok i have a question i just bought a 94 Z28 with the bose system and aftermarket deck all speakers seem to work as they should but sub not working does anyone have any answers for this problum?
CamaroHeed
Mar 18, 2020 09:50 PM
Rodrigues
Sep 5, 2002 05:40 PM
Chicago94Z28
Aug 28, 2002 08:31 PM
jwright3SS
Jul 30, 2002 03:49 PM
96CamZ
Jul 27, 2002 04:13 PM
