after market amp
Old Apr 21, 2003 | 10:31 PM
blackz151's Avatar
after market amp
I am gettin a after market 4 chanel amp for my mids and highs with after mark speakers, how do i go bout gettin rid of the stock amp?
Old Apr 22, 2003 | 12:23 AM
PaulN64's Avatar
do you have a Bose? If not, then look in the spare tire well and you can see a black panel. That's the stock amp. Just unbolt it and unplug the wires.
Old Apr 22, 2003 | 01:12 AM
blackz151's Avatar
i have bose
Old Apr 22, 2003 | 11:45 AM
Rashiki's Avatar
If you have the 5 speaker bose system, the amps are in the 5th speaker enclosure on the drivers side of the trunk. Take the whole top panel off, remove the entire enclosure, remove the speaker (you'll need to get to get at a screw here) Then sit down and take out all of those damn gold screws. Pull it carefully apart, and there are your amps. How you plan on bypassing them i have yet to figure out..i'm in the process as we speak!
Old Apr 22, 2003 | 12:14 PM
blackz151's Avatar
i think i am gonna take all the wires form behind the HU and run them to the 4 chanel amp
Old Apr 23, 2003 | 11:07 AM
Rashiki's Avatar
I think that would be your best bet... let me know when you find out where the front speaker wires go to inside the car
Old Apr 23, 2003 | 11:22 AM
ShaggySS's Avatar
yes you will run into problems doing this, best bet is to run the wires from the amp directly to the speakers. the amps will mess with the signal.
Old Apr 23, 2003 | 04:09 PM
RallyRedTexan's Avatar
Are you adding an aftermarket HU? That and new speakers are generally the best first step to take in getting better sound. From there adding a sub/amp and then a 4 ch. amp would be the next steps.
Old Apr 23, 2003 | 09:14 PM
blackz151's Avatar
its gonna be subs and amp then a 4 chanel amp. Off a aftermark HU
Old Apr 24, 2003 | 01:33 AM
Just unplug the speakers and ignore the stock amp. You'll need to run all new speaker wire either from the head unit or from the 4 ch.
Henson071
Dec 30, 2015 09:55 PM
themex2002
Sep 2, 2015 03:47 PM
Aug 17, 2015 09:50 AM
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 10, 2015 02:23 PM
