adding another sub
Old May 2, 2003 | 07:11 PM
moneyshotz's Avatar
adding another sub
Hey Guys,
Right now I have a mono AMP that can handle 2ohm or 4ohm. And I currently have a 12"sub at 4ohm connected to it. Would it be possible to add another 12" at 4ohm and run it in parallel then run that to the amp?
I have the MTX 6500D. ANd a JL 12w3. And I want antoher 12w3
Old May 2, 2003 | 07:43 PM
LS1 RULZ's Avatar
Get another sub like the one you have and then connect it in parallel with the one you have to get a 2ohm load for your amp.
Old May 2, 2003 | 08:41 PM
moneyshotz's Avatar
Ok.. So there should not be any power issues?
Old May 2, 2003 | 09:47 PM
LS1 RULZ's Avatar
No, no power issues. I'm running my 6500D into a single 10" Alpine Type-S at 2ohms and I have no problems at all.
Old May 2, 2003 | 10:08 PM
moneyshotz's Avatar
So it shouldnt matter that I'll be running 2 subs at 2ohms into that amplifier?
Or...I was thinking about just replacing my 12w3 running at 4ohms with a sub running at 2ohms. How is your 10" Alpine Type-S? How did it compare to you JL? Is it cleaner? I saw it here for this price.
http://www.etronics.com/product.asp?...1d&SVBName=309
Old May 3, 2003 | 10:59 AM
LS1 RULZ's Avatar
The Type-S blows away the 10W3 in every way. The 10W3 is an excellent sub but the Type-S is a better match for the .6 cubic foot Vantage Stealthbox I'm using.
Old May 3, 2003 | 12:22 PM
firebirdude's Avatar
You will have no problems running another 4 ohm 10W3 off that amp. Get that... OR two 4 ohm Type-S's !!!!!
Old May 3, 2003 | 04:17 PM
stik6shift98's Avatar
nope u will have no power issues
Old May 3, 2003 | 04:28 PM
moneyshotz's Avatar
so is the Type-S really better than the W3? I'm reading some mixed reviews.
Old May 3, 2003 | 05:42 PM
LS1 RULZ's Avatar
All I can say is that for me the Type-S hits harder, plays louder and, to my ears, goes lower than the 10W3 D4 I used to have. Nothing against the 10W3. Like I said before, the Type-S just seems to be a better match for the enclosure than the 10W3 is.
Old May 3, 2003 | 08:58 PM
RallyRedTexan's Avatar
I agree on the Type-S. But I would go with a W3V2 over the Type-S. But on the older model W3, I'd go with the Type-S. Can't beat the Type-S pricing. Well, exept you'd have to buy two subs instead of one .
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
cmsmith
Aug 27, 2015 06:37 PM
