99 SS Double Din Install
Old Jun 5, 2010 | 12:48 PM
Chevycrew's Avatar
Spent my friday installing a new stereo in the camaro.
I used a Scosche GM1599B (equivalent to the Metra 95-3302) mounting kit with a Pioneer AVH-P3200BT stereo.
I extensively modified the mounting bracket, but it got the stereo sitting on the bottom stock plastic like I wanted.
Then the work was on for the bezel.
Overall I have about 12 hours in the install, mounting, wiring, bondo, paint, etc.
Paint is rust-oleum hammered gray (more silver).
Old Jun 5, 2010 | 06:02 PM
unvc92camarors's Avatar
Wow. Looks good. Definitely some nice work that you did on it.
Old Jun 5, 2010 | 06:13 PM
Chevycrew's Avatar
Thanks, other than the paint, I wanted it to look factory. Tried to smooth and blend the bezel around the switch locations to get a nice flow going. I was nervous about cutting it up, but no regrets here!
Old Jun 5, 2010 | 07:00 PM
Other than it being the only luxury like item in the Camaro's spartan interior, it looks good.
I was thinking about getting one of those but ended up just going with the MVH line because it fit without modification. Might have thought twice about it had I seen this first but then again, I'd be nervous about cutting it as well.
Old Jun 5, 2010 | 08:24 PM
Chevycrew's Avatar
I had figured if I messed up it was only 30-50 for a new bezel to go back to stock.
I really hacked up the bezel, but a couple hours with bondo and it looks like it was meant for it.
Old Jul 10, 2010 | 11:59 PM
Interceptor1's Avatar
Congrats! that is a nice piece of work you did!
I would like to do the same on my '96 but the dash is like 3 stacked pieces so it's more involved.
Old Aug 23, 2010 | 05:44 PM
1badeagle's Avatar
That looks amazing. Are you a body man I was super confused when I first read that it took about 12 hrs to install.
Dustin
Old Nov 25, 2010 | 04:56 PM
hadkin's Avatar
Re: 99 SS Double Din Install
Or maybe he read my post on LS1tech.com from a year and a half ago, and knew what to do....
http://www.ls1tech.com/forums/stereo...din-bezel.html
I'm just saying, give some credit here. My post comes up first when you google "double din camaro" since its been viewed soo many times.
Old Jan 8, 2011 | 03:32 PM
Chevycrew's Avatar
Just like anything, someone, somewhere has done it first.
I read a few different installs on the web, then did my own since there were things I didnt like about the others.
I do have experience in composites work, but bondo is pretty easy to work with.
Nov 18, 2023 07:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
DrMilhouse
Oct 2, 2002 05:03 PM
craigffb
Sep 5, 2002 08:17 PM
CobraEatr
Jul 22, 2002 09:49 AM
