97 brake light socket
Old Sep 2, 2010 | 10:29 AM
michaelrulaz's Avatar
So i have a 97 camaro RS, and i was having problems with my right brake light, it only worked sometimes and finally stopped working all together, well i took it apart and realized the bulb was blown so prompted to remove it, when i realized the light bulb was stuck in there and the socket was corroded and i finally got the bulb loose and it ripped the metal out of the socket. so i went to autozone to get the new brake light socket and they want 53.00 dollars compared to all the other car brake sockets being roughly 3-10 dollars. any advice on aftermarket brake sockets? or could i use another gm socket? i know it may not fit in the hole but i create a way to make it fit. im just wondering if the wiring may cause problems, i was just going to cut and splice. any advice?
Old Sep 24, 2010 | 08:39 PM
crazypurgatory's Avatar
Lightbulb
Try the dorman #85866.
It should work I forget if I had to break off one of the tabs on the tail light lens I don't think you have to.
I have one on my 97 on the passenger side.
Old Oct 5, 2010 | 09:39 AM
red97rs's Avatar
i had the same problem... i just baught one that used the same bulb, the only difference was that it mounted and it had 3 wires coming out instead of 2. but mine works fine now, and the new socket only cost around $7.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
