2 extra wires in factory radio harness
Old Aug 12, 2003 | 09:50 PM
$hawn's Avatar
I have two extra wires that come out of the same bundle of factory stereo wires. First of all a pervious owner before me cut the connector off the stock harness, and there is an extra brown wire and a grey wire more light grey than anything. Only factory grey wires are left front spke(-) light grey and the headlight dimmer wire is grey. Only brown one is for left rear spke(+), so one of the brown ones has to be an extra. Think I should just connect them one at a time and see what works and dont work? Or are there supposed to be two extra wires? Thanks for any input.
Old Aug 12, 2003 | 11:51 PM
NineSevenWS6's Avatar
www.installdr.com
the one is porbably the dimmer, if youve found the illumination..the voltage should go up and down as you play with the dimmer switch.
Old Aug 15, 2003 | 10:31 PM
$hawn's Avatar
Think if the one for the left rear speaker(+) was hook up wrong it wouldnt play would it? And I have 3 wires that are cut, blue for the power antenna turn off, theres no pink wire for it so I cant hook that one, a orange w/white stripe goes to ? and a solid orange for the headlight dimmer for proabally that light grey one. But I at least have one extra brown wire.
Old Aug 17, 2003 | 10:40 PM
$hawn's Avatar
Any ideas?
hotrodyou1
Dec 20, 2014 10:05 PM
UT Trans AM
Nov 15, 2006 11:20 AM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
mjcent922
Jul 27, 2002 12:42 PM
