1995 Bose CD power antenna question.
Old Nov 27, 2003 | 04:06 PM
Eddie95Z28's Avatar
I have a 95 camaro that didn't originally have a power antenna. My question is. IS there a remote wire spot on the deck, and will it lower the antenna when I ply a CD?
Question 2: If it doesn not lower the antenna for CD play what is the power antenna remore voltage so I can wire in a manual switch?
Old Nov 27, 2003 | 11:58 PM
Javelin3o4's Avatar
if its just a universal power antenna then it would be hooked up usually to a 12v const. and a 12v switch, so when both lines are powered the ant goes up, when the car is shut off or radio turned off the 12v switch signal goes off and the ant retracts. also if its a universal ant, if you pull the deck out your should see the wires that were connected for the power and be able to wire a switch up to it.
Old Nov 28, 2003 | 02:47 PM
Eddie95Z28's Avatar
It isn't a universal power antenna. It is out of a later model LS1 WS6. What I was wondering is if the 1995 Model 5-piece BOSE H.U. lowered the antenna when a CD is played?
And what was the remote line voltage if it didn't.
Thanks for the reply.
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
siguy
Nov 27, 2014 10:07 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 3, 2002 07:29 PM
