12 inch sub in rear driver cubby?
Old Feb 22, 2011 | 09:12 PM
firebirdStud's Avatar
Smile 12 inch sub in rear driver cubby?
I did search, and nothing.
I am wondering if anyone has fit a 12 inch sub in that little cubby in the drivers side rear compartment? I bought the car with a 10 inch in there, but I want to upgrade it to a 12 if I can sneak it in there.
I can make my own inclosure, and if I had to I could mount it with the magnet facing out.
I just just dont want to lose the T-Top holders...
Thanks for any opinions!
Cody
Old Feb 23, 2011 | 06:11 AM
Chevyssoccer's Avatar
Re: 12 inch sub in rear driver cubby?
i dont think it will fit, or have the needed volume, but give it a try. If you mount it reverse wont it be in the way of the T-tops. they sit very close to the face of the cubby.
Old Feb 23, 2011 | 06:29 PM
Nope, I can move the speaker in a bit. Im just throwing out suggestions.
Old Feb 24, 2011 | 01:29 PM
97FormulaWS-6's Avatar
The issue isn't going to be if it can fit or not, the issue is going to be the airspace the speaker needs. There's not a ton of volume in that small area, and most 12" subs need a minimum of 1 cubic foot of air in a sealed box and that space isn't even close to that.
Old Feb 24, 2011 | 07:17 PM
Damnit, you are absolutely right there. I guess I never started to think about that aspect.. only if it would fit or not.. hmm
Old Mar 31, 2011 | 12:49 AM
lymlyt96's Avatar
If you're capable of making your own fiberglass enclosure it actually will fit you have to know the minimum amount of space your sub will need take measurements inside the cubby hole and go from there. I made two enclosures one for each side and I made them to where I could easily unplug em and take em out if I needed to shed some weight for a race. This was a few years back but I used the audiobahn eternal series with a ma audio 4000watt amp it was a competition setup running over 12,000 watts throughout the whole system. I ended up selling the entire system I got older and my ears just couldnt take the abuse anymore. For the enclosure I started with a base plate and a speaker ring and built a frame around that, in order to get the amount of space you need the speaker will sit out about 2 inches.
Old Mar 31, 2011 | 05:02 PM
wow that is really cool! I do have a question though, If the speaker had to sit out 2 inches, did the T-Tops interfere with the speakers when they were in the trunk? I drive around with the tops off 99% of the time so this would be a deal breaker.. I like the dual speaker idea though for sure.
Old Mar 31, 2011 | 06:05 PM
yes it will, I have one of my amps there, its not two inches thick and one of the t-tops just touches it. plus speakers move in and out and arent made of metal
Old Mar 31, 2011 | 09:49 PM
lymlyt96's Avatar
T-tops fit without a problem
Old Apr 1, 2011 | 04:01 PM
Hmm, I may have to save up and put two JL 10's in there then.. haha. 12's require more space, and Im not entering competitions. I just want it to sound ballin when Im cruisin around inside the car. I dont need it to shake the teeth out of people a block away
Old Apr 1, 2011 | 10:52 PM
lymlyt96's Avatar
LOL that would be a good idea goin with the 10's and a good idea staying away from competition systems nobody will want to ride with you when you crank up the system halfway and your eyes start to twitch and your throat closes up lol you look at the passenger and there sayin please turn it down TURN IT DOOOWN!! lol ahh yeah those were the good ole days..
Old May 10, 2011 | 04:15 PM
rv93's Avatar
im not nearly as ambitious as OP, but it seems that fitting a 10" in that cubby is easy? i would love to do that. can i get a premade box? ive never worked with fiberglass before. also, does the factory monsoon system they used in 02 have a sub output? thanks
Old May 10, 2011 | 09:58 PM
You can buy one, but the cheapest I found was 150. F that noise. Im almost done building my bigger box for that drivers side cubby, and I have it spec'ed out at .65 cubic feet. Not bad! The one that came with the car was only .3. Woot Woot! Just waiting for my 10 inch JL 3w3 sub to show up so I can cut out the mounting hole, then Ill seal it all up and shoot it with spray paint to help seal it up. The front side you see will be carpeted though.
dale3in98
Feb 14, 2015 12:18 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Patrick Davies
Aug 8, 2002 08:30 AM
