1 12" JL where do i put it
Old Jan 16, 2004 | 03:23 PM
93transam1234's Avatar
OK i got a 12" JL in a box it will fit in the well good enuf that i can close the trunk. it is faceing up twords the rear window. Is ther a better way to have it installed?
Also i have an old pionerr 1300 whatt amp brigable. If i want to hook up the 12" and then 2 10" Jl's what would be the best way to do this?
Old Jan 17, 2004 | 03:16 AM
PaulN64's Avatar
I'd look into a stealth box
http://subthump.com/acamarostealth.htm
Old Jan 24, 2004 | 06:33 PM
GP-1's Avatar
If it'll fit that way, face it toward the back of the car..
Old Jan 24, 2004 | 07:32 PM
GSteg's Avatar
Re: 1 12" JL where do i put it
So you want to run a 12" and 2 10" at the same time? That's a waste of space and you will not get any benefits.
What model number is your subwoofer(s)?
In your opinion, what is a good way to have the box it? If it is good enough already, why change it at all? There is no wrong or right way to put the box in. If it suits you well, then that's all there is to it.
Old Jan 24, 2004 | 07:48 PM
GP-1's Avatar
Sorry to disagree, but the bass will be stronger if you give it something to reflect off of.. as opposed to pointing it forward into the passenger compartment...
by the way... I agree about the subs... Run the 12".. or run the 10's".. not both..
Heathen1
Jan 2, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
