01 Camaro parking lights
Old May 11, 2010 | 06:55 PM
sprinkknot's Avatar
So on my v6 Camaro the parking lights don't turn off or I don't know how. Since it is illegal to drive with them on in California, I'd like to fix this, anyone know a fix or a reason why it's doing this?
Old May 11, 2010 | 07:12 PM
BloodyZ28's Avatar
Sounds like you mean the DRLs (daytime running lights). They're the orange lights on the front that come on when you put the e-brake down all the way and are always on. As far as i know, they're not illegal anywhere in North America, but I don't know about Cali specifically.
If you want to disable them anyway, there's a guide here http://bit.ly/bz1STb
Old May 11, 2010 | 07:23 PM
sprinkknot's Avatar
Are they on the back too? Because apparently the yellow lights in the back are also on according to my friends.
Old May 11, 2010 | 07:38 PM
BloodyZ28's Avatar
Those are your turn signals (the centermost amber lights on rear), if they are on all the time, that's quite strange. On any and all 97+ taillights they shouldn't come on unless your turn signal or 4-way flashers are on.
Is it just the amber lights that are on, or are the center section, outside sections, and the rear side marker lights also on?
Old Jun 28, 2010 | 12:32 AM
Chevycrew's Avatar
Im currently working on a quick fix for the Daytime Running Lamps. They appear to be the park lights at first glance, but the are actually the front turn signals that are activated by the DRL module.
Im going to disable the DRLs on my car, but I want to leave the auto headlamps.
There are a couple differences in the wiring for DRL cars and non-DRL cars. It should just be moving 2 wires.
Ill update as I go...
Old Jun 28, 2010 | 10:50 PM
Chevycrew's Avatar
Ok test went well, simple fix!
To remove the Daytime Running Lamp function (without removing auto headlamps).
Find the DRL module behind the radio
On the large connector, cut wires in the following pin locations.
Pin B and E, these wires were Dk Blue and Dk Blue w/White
Pin G and C, these wires were Lt Blue and Lt Blue w/White
Now hook the wire together where they come out of the harness.
Lt Blue to Lt Blue w/White
Dk Blue to Dk Blue w/White
Test to make sure turn signals and auto headlamps function properly.
Note: the 4 cut wires on the DRL side will no longer be used.
Old Jun 29, 2010 | 10:37 PM
BloodyZ28's Avatar
Theres a writeup for this, here:
http://xse.com/leres/ss/drl.html
Old Jun 29, 2010 | 10:48 PM
Chevycrew's Avatar
That writeup removes both the DRL and Auto headlamps.
I retained the auto headlamps while deleting the DRLs.
Gtpguy
Jan 26, 2015 04:50 PM
fpete1992
Dec 11, 2014 03:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
