Zeta: The Best Thing Going
Old Sep 25, 2006 | 06:45 AM
  #16
guionM's Avatar
Re: Zeta: The Best Thing Going
Originally Posted by Z284ever
I think we'll just have to agree to disagree on this, because as far as I know this is completely false. "Lego-like" construction as described and 21st century requirements for rigidity and crash protection are not at all compatable.
The key to that achievement is a new front-end module that contains the headlights, horns, condenser radiator fan module supports, windscreen washer bottle and airbag sensors.
“The front-end module will … positively affect crash repair costs for low-speed impacts,” confirmed Emmanuel Vlontakis, Holden’s engineering group manager – exterior systems.
“Repairs will be more rapid because the front section is easily unbolted and replaced – as opposed to the traditional ‘weld on’ front-end design.
Holden is the first GM division globally to use this advanced, all-in-one unit and the VE Commodore is the first Australian-built vehicle to take advantage of this technology, which until now has been mainly the domain of high-end imported vehicles.
“Improvements to repair and maintenance costs are a highlight of VE design,” added Vlontakis.
The module also improves manufacturing efficiency, creating a walk-in front-end that resolves close to 30 assembly-related ergonomic issues. It also provides a more consistent fit and finish.
Holden is the centre of knowledge in the General Motors empire for the VE platform - a platform designed and built on a modular framework which allows easy transformation into a coupe, a wagon, a hatch or just about any other bodystyle you care to imagine.
The platform - or flexible architecture, if you like - allows easy stretching and compacting of the wheelbase, and many other modifications to let General Motors utilise it around the world quickly and cost effectively.
Old Sep 25, 2006 | 07:20 AM
  #17
guionM's Avatar
Originally Posted by 90 Z28SS
Im not an engineer , but I would have to logically agree with that . Unless Im not understanding what your saying Guy . I dont get how an entire front subframe could be bolted on and be strong enuff .
Not the entire front subframe (which doesn't exactly exist), but the front support structure. The section that bolts on can be designed to extend the car's length.
The front box section of the structure is also made so that the front suspension assembly can be attached at different points, creating different wheelbase lengths. You can see that in the pictures above and the side X-Ray view below.
Just in that front section alone, you can create a longer or shorter car in both wheelbase and in length, simply by bolting on the suspension and front support structure. Doesn't affect crash worthiness. Far cry from a Delta or Espilon.
In the past, manufacturers had to create an expensive whole new substructure. Many of the body and undercarrage structures are much the same way, where you can create a wide variety of models off that structure.
As I mentioned in another thread, Camaro ISN'T a Zeta per say, in that you can not do the same thing with it's sturcture. Camaro is based off of some of the same ideas as the Zeta, has some of the same componets as Zeta, and can be made on the same assembly line as Zeta. But if anything, Camaro is a spinoff of Zeta as much as Mustang is a spinoff of the Ford DEW chassis... why it needed separate approval, while the big coupes don't.
Old Sep 25, 2006 | 09:44 AM
  #18
Z284ever's Avatar
I think they're referring to the assembly behind the front fascia, which includes the headlights and radiator. NOT the whole structure forward of the dash.
Old Sep 25, 2006 | 09:54 AM
  #19
Capn Pete's Avatar
^ neat pics and info Guy!!
Old Sep 25, 2006 | 10:01 AM
  #20
Capn Pete's Avatar
A Camaro, an Impala and a Lucerne replacement, pretty much fill one plant.
Is that what we should expect to see being built in Oshawa then?
I remember awhile back hearing it might be (or potentially have been):
- Camaro
- Impala
- Cadillac DTS
- Buick Lucerne
- Pontiac G8
.....never heard anything real rock solid on that, but since then I think I heard that the revised Grand Prix / "G8" is going to be on a different structure now (not Zeta based) and just above someone mentioned DTS being cut.
Any more news/rumours/gossip about a GTO though?? I haven't heard much here, but over at the LS1Tech camp, there was some serious talk about an '09 GTO (likely to be seen in January at NAIAS) ..... I suppose they could cram the GTO in with the Camaro, Impala and Lucerne, eh?
Old Sep 25, 2006 | 12:06 PM
  #21
Z284ever's Avatar
- Camaro
- Impala
- Cadillac DTS
- Buick Lucerne
- Pontiac G8
There may very well be Zetas beyond Camaro, Impala and a large Buick - but at this point that would be PURE speculation.
As far as a GTO goes, I personally have nothing to report. Nothing seems to be going on with that. As far as a GTO concept at Detroit, that's roughly 100 days away. I think we would have heard some sort of rumor or leak by now in regards to one - if there were one.
Old Sep 25, 2006 | 02:27 PM
  #22
Capn Pete's Avatar
Think they maybe learned something after the "worst kept secret" last year????
Old Sep 25, 2006 | 03:37 PM
  #23
90 Z28SS's Avatar
Thanks for the pic and the explaination Guy , seeing what exactly IS modular now clears up the confusion I had
Old Sep 25, 2006 | 04:13 PM
  #24
Z284ever's Avatar
Well kept secret or not, for there to be one at NAIAS, someone needs to be working on one.
Old Sep 25, 2006 | 05:16 PM
  #25
Capn Pete's Avatar
Is this that information you "didn't think I'd like to hear" in that other thread about the GTO?? I guess this is what I get for believing any information posted somewhere other than here on ??!!
Well, I might as well start hoping for another Firebird if that's the case with the GTO!!
Old Sep 25, 2006 | 06:16 PM
  #26
ehaase's Avatar
So will the DTS replacement use Sigma, as suggested by Evok at C&G? Evok seemed to hint the STS and DTS may be replaced by one car, with a DTS and long wheelbase DTS-L. Other insiders have suggested the DTS replacement would be on Zeta.
Old Sep 25, 2006 | 06:24 PM
  #27
Z284ever's Avatar
I'm not certain, but Evok's scenario appears very plausible, and actually makes alot of sense.
Old Sep 25, 2006 | 07:12 PM
  #28
formula79's Avatar
What if the GTO concept was developed in Austrailia and shipped here at the last minute?
Old Sep 25, 2006 | 08:36 PM
  #29
guionM's Avatar
Wink Re: Zeta: The Best Thing Going
I did not say the: "whole front structure in front of the dash".
I specifically said: "the entire front support structure is manufactured separately, and simply bolted on...".
...which as the pictures I posted clearly show and the press release and news article I quoted plainly states, pretty much removes all doubts here. That ain't just a front fascia in that 3rd pic.
Again, nothing like the Delta or Espilon or anything else GM currently makes.
Multiple wheelbases. Different front end sections can be quickly manufactured and bolted on to change the car's length. Other sections of the car are equally adaptable. Modular Lego-like construction in that you don't have to engineer an entire new car, just the part (or parts) that you are going to subsitute.
The rules as we know them are out the window on this structure.
Well, actually.....
Today is September 25th.
Reports about Camaro showing up at NAIAS didn't surface till November.
The new Dodge Charger was kept secret till November.
Corvette didn't surface till the 1st week in December.
Cammo production Mustangs did show up around this time before unveiling, but they were less than a year away from production.
Pontiac DOES have a "vehicle" planned for NAIAS. Excuse me if I don't say what...... last year's flaming e-mails and thread-erasing over hinting at a NAIAS Camaro are still fresh in my mind.
Ain't gonna go there this year. But I think I can say it might be of some intrest here.
Old Sep 25, 2006 | 08:40 PM
  #30
guionM's Avatar
I'm not at all yet convinced that Cadillac's DTS replacement will be on Zeta.
Sigma in itself is more than capable of being very flexible. Just look at the models it's already under.
