V8 Solstice from GM
Re: V8 Solstice from GM
Originally Posted by NikiVee
BTW is was 1999 and it was Green in color with I believe an LS1. It was on the Hot Rod East Coast Power Tour at the time along with the first Chevy Nomad concept.
I have a picture of it somewhere.
That just made me feel old, but at least I can sorta pinpoint when that car was around
Originally Posted by Z28x
How about an Aluminum S/C HV V6? Lighter than a V8 and more power than a Turbo 4 cyl.
The rest of the powertrain might require more beef with the V8, but the blower probably offsets the two extra cylinders pretty closely.
Originally Posted by Jason E
That was before 1999 because I remember reading the article...in my high school library...I graduated in May 1998.
Originally Posted by PacerX
"If it'll fit a V6 and an I4, it'll fit a V8."
Originally Posted by Patches O'Houlihan
If you can dodge a wrench, you can dodge a ball.
Originally Posted by muckz
Depending how they will engineer the turbo set up, but it's possible to have 100% of the torque from somewhere like 1800 RPM all the way to 5000 - 5500 RPM. Just look at Audi/VW 2.0T engines and Volvo's turbo engines.
It would be nice if GM started their own direct fuel injection systems. I bring this up because the Audi/VW engines are or will be taking advantage of the higher compression tolerances their FSI engines allow, thus reducing turbo lag even more.
Originally Posted by RussStang
Yeah, but those Audi engines aren't going to supposedly make 240hp or more. My bet will be that there will be at least alittle lag, although nothing like an Evo.
The STI's 2.5L turbo 4 has good low-midrange tq. It makes a nice peak of 300 lb/ft as well.
The drivetrain will be just fine with a v8. The rear end is from a near 4000 poud car (as well as the upgraded version for the CTS-v) And the trans is from a truck with at least a 5k tow rating. Im sure it can handle a LS2.
For manuals, I wouldn't trust anything but a T-56 behind an LSx, and since it's a 5-speed it isn't a T-56.
Expect 6 speeds behind GXP and Redline models ( I think I remember that right, I'm getting old
) Let's see what the turbos are packing before we start the "there's gotta be a V8 in this car to be fast" talk. When the aftermarket catches up with the turbo ecotecs, there will be no issues with sky high power numbers.
A little tidbit...peak torque on the FI motors will be well under 2000rpms and flat as a tabletop. GM powertrain really outdid themselves in tuning on these beasts.
) Let's see what the turbos are packing before we start the "there's gotta be a V8 in this car to be fast" talk. When the aftermarket catches up with the turbo ecotecs, there will be no issues with sky high power numbers.A little tidbit...peak torque on the FI motors will be well under 2000rpms and flat as a tabletop. GM powertrain really outdid themselves in tuning on these beasts.
) Let's see what the turbos are packing before we start the "there's gotta be a V8 in this car to be fast" talk. When the aftermarket catches up with the turbo ecotecs, there will be no issues with sky high power numbers.The only issue will be whether the supporting cast is up to the task (chassis, transmission, rear end, driveshaft, clutch).
Originally Posted by Doug Harden
But that' s the great thing about turbo cars...the initial hit isn't as brutal, so drivelines
"should" hold up better....
I have to think about this...
The way I got this figured, 400 ft-lbs is 400 ft-lbs. Now, that might be very wrong, so I shall put my dunce cap on and ponder...
Go sit in the corner young man......of course it is, but most driveline failures are during the initial hit....you know, trying to move 3***#'s from a dead stop is harder than pushing it faster after already moving.......come on now, I'm just playin' Mr. Optomistic.....
