Think about what a beast the LT5 would be...
Re: Think about what a beast the LT5 would be...
Originally Posted by RussStang
I still find it very doubtful for a minor HP bump to run its top end up another 15mph.
Find me an engine with 4 cams over a single bank. That is something I would like to see. Quad cam is a term I have heard used multiple times to describe DOHC v6 and v8s, and could be applied for and v engine.
I'm surprised someone hasn't copied and "sweatshop-produced" lt5 heads. Even if they were the ultimate in high HP they have a def cool factor!
Interestingly I just read a blurb or two in MM&FF when they asked Jack Roush about the drag pack Mustangs, essentially Jack said it was a mistake for Ford to adopt multivalve technology as far as the street was concerned and that they should have concentrated on an pushrod motor like GM and DCX instead, otherwise he said the die was cast and the mod motors are pretty good, they have crate engines in the works all the way up to 6 liters.
Jack Rousch should know what he is talking about.
Multivalve engines are great in a ***** to the wall sort of way, but IMO I can agree with his thinking as I see it. Airflow technology has advanced to the point where even 2 valve engines can make gobs of power all over the map and in the region that most engines operate on the street, multivalve engines are overkill (btw they typical shine in the mid lift plus range), unless of course you are handicapped by a 3.550" bore as mandated by some short-sighted asshat that wanted to stuff a V8 in both RWD and FWD configurations forcing you to go to a multivalve layout to be competitive again only to be handicapped by stoke limitations further limiting the over all displacement of the motor unless you add additional cylinders again only to be handicapped by a dip**** CEO who thinks a certain car should only have a V8 when it could've had a smok'n 5.8 to 6.8 liter V10 - but I digress - Anyways I think part of the low speed delimma of multivalve engines stems from both port volume and a lack of quench in the combustion chamber, something a well designed 2 valve engine doesn't suffer from.
Or tumble for that matter, one of the tricks used on the Ford 3v is a shutter in the intake port to promote tumble. All this tumble and swirl stuff is really to keep the air/fuel mixture homogenized until you can get the revs up where the air is flowing well enough to keep it in suspension.
I do have a question, if Ford has a problem with it, why didn't they fix the heads with a new design instead of putting a band aid on it? I don't see anyone else having problems with this, but then again i don't frequent any OHC performance boards so maybe its not just a Ford problem. I know the 4.7 Chrysler motor has the same problem as the Ford and I think there are some similar problems with their V6 OHC motors, which would explain why they don't get that great mileage.
RX Speed Works
Jul 24, 2015 02:25 PM
