Solstice 1LT
Old Dec 18, 2006 | 03:51 PM
  #16
90 Z28SS's Avatar
1 word .....Mallet
If you coulda afforded a brand new 02 SS or WS6 , its likely you can afford to ship Mallet a new solstice or sky . Be patient , then pick it up with a LS2/6-speed and still have the window sticker and plastic on the seats . A 4.8/5.3 swap would be even cheaper . And it does look like it shoulda been there in the first place and has a full warranty to boot .
If thats what you really wanted
Old Dec 18, 2006 | 04:14 PM
  #17
bossco's Avatar
4. A V8 isn't the answer to everything.
Did somebody say Witch?
Old Dec 18, 2006 | 04:33 PM
  #18
Z28Wilson's Avatar
Originally Posted by jg95z28
From what I've read, the LS7 Solstice Hot Rod did handled quite well.
It sure did. Carbon fiber everything to keep weight in check, Brembo brakes, aftermarket suspension pieces....sounds very production pheasable, especially for under a Corvette price!
Originally Posted by Hot Rod Mag
The suspension hangs on essentially stock Solstice components but uses top-of-the-line parts, such as Ohlins coilover shocks and big Brembo brakes. The suspension calibration is another area where GM's engineering expertise shined through, as the car was good right out of the box and needed only fine-tuning when it hit the test track. A stock Solstice weighs just under 3,000 pounds, and the drivetrain swap added about 700 pounds to our car's girth, so a lot of thought went into a weight-loss program. The Jenny Craig solution was many carbon-fiber body panels, plenty of lightening holes drilled where there were no structural issues, and the removal of anything that was deemed not absolutely necessary.
That's almost a 3700 pound Solstice before you start hacking it up.
Old Dec 18, 2006 | 05:19 PM
  #19
number77's Avatar
Originally Posted by Z28Wilson
Which is exactly why it shouldn't be done. A factory V8 Solstice goes against what the car is and why it was created in the first place.
This has been pretty much beaten to death. I think GM is right on the money with where the Solstice and Sky are positioned. Let the megabuck tuners have fun with V8 Kappas....It's more important that GM show their skill in other areas besides throwing their already proven small blocks into everything.
I'm not recomending GM stop producing them as they are. I am suggesting an addition.
I am suprised you older guys are so against a light car with a v8 driving in a straight line.
Makes me wonder what he old guys said back in the 60s.
Old Dec 18, 2006 | 05:27 PM
  #20
Z28x's Avatar
The GXP turbo I4 is more powerful than a lot of 60's V8s
Old Dec 18, 2006 | 05:34 PM
  #21
bossco's Avatar
Naw wouldn't weight that much, a solstice weighs almost 3,000 lbs with its drivetrain in place, the LS7 drivetrain weighs 700 lbs, I'd say it probably only added maybe 300 pounds give or take relative to the original weight, so LS7 solistice with no weight reduction probably only weighs 3200 to 3300 lbs.
Old Dec 18, 2006 | 07:18 PM
  #22
Z28Wilson's Avatar
They said the LS7 drivetrain added 700 pounds to the car...I took that to mean 700 pounds over and above the stock Ecotec drivetrain. Remember you're not just swapping the motor, you need a beefier trans, rear end, extra bracing....
Still, I just don't really see a point in a $30,000+ V8 powered Solstice/Sky. This is supposed to be an entry level, European-style sports car.
Old Dec 18, 2006 | 07:34 PM
  #23
Josh452's Avatar
Thankfully, such a thing will not happen.
The Solstice and GXP are fine as is. Said from an owner of the actual car.
Old Dec 18, 2006 | 09:28 PM
  #24
Z284ever's Avatar
Right now there is a 4cyl 260hp/260tq turbocharged engine in the Solstice GXP. Why doesn't GM just opt out for the Vortec 4.8L V8? It has 295hp/305tq. It would put the Solstice 0-60 in ~5 seconds and shouldn't cost all that much more. It could be marketed as a V8. If we could really strip it down we could maybe get it to $22k? Essentially, it'd become a poor kid's Camaro.
Whadayathink?
Why don't you get a stripped, hose out, 4.8L, 5 speed manual, Silverado? You can get it for quite abit less than $22K.
  #25
Raven99's Avatar
Cool
Originally Posted by Jason E
I really, really want a Solstice GXP coupe...
Badly...what a car that would be.
word
Old Dec 18, 2006 | 10:26 PM
  #26
number77's Avatar
Because it would be slow.
Old Dec 18, 2006 | 10:50 PM
  #27
Z284ever's Avatar
For your $22K budget, you could add a blower.
Old Dec 18, 2006 | 10:54 PM
  #28
97z28/m6's Avatar
would be a killer package. would make a better factory package.
Old Dec 19, 2006 | 07:12 AM
  #29
Z28Wilson's Avatar
So, what you're looking for in essence is a $20,000 car that runs 12's off the showroom floor. Good luck with that.
Old Dec 19, 2006 | 07:42 AM
  #30
cASe SenSiTive's Avatar
Exposed Member
