Saw '08 CTSs on the Caddy Lot
FE2 AWD has the FE3 brakes.
I dont get why the FE2 RWD gets aluminum calipers, and the FE3's larger brakes get cast iron? You would think to reduce unsprung weight, that you would use a light weight aluminum caliper, not to mention disapate heat?
Calipers play practically no part in heat dissipation. A cast iron caliper would be stronger and therefore less prone to deflection when you're heavy on the pedal.
Ehhh...calipers get hot man, and that makes brake fluid get hot. Hot fluid is not fun. Cast iron would be stronger, but I have not seen a problem with OE or Aftermarket brake set ups, using large brake calipers made of aluminum.
This is getting off topic quickly. Both rotors and calipers play their part in heat dissipation, and I doubt that typical drivers of a CTS are going to notice any of the changes in brake options mentioned so far. Most cars aren't pushed hard enough for it to matter in typical use.
I'm glad to hear that the new CTS is a real beauty. I'm looking forward to seeing one in person.
Dan
Dan
Its not a matter if the driver will notice a feel in braking during a few laps at GingerMan, Willow Springs, or Lime Rock, but the added unsprung weight of a cast iron caliper will effect the ride of the car vs a car equiped with aluminum replacements.
Can we please stop talking about brakes? I want to hear others impressions of the car. How do you fit in the seat? How is the view, any big blind spots? Any good places to rest your elbows? Legroom for front and rear passengers?
Dan
www.cadillac.com is down. WTF?
I wanted to build and price. If it runs 43+k, I guess I'm back to the 335i.
GM is learning! If you can tell the difference between a ZL1 Copo and a base model X44 Camaro by the dog dish rims, that means youre really into cars.
If you can tell the difference between a Vette and a Z06 that just means you have the gift of sight.
I just tryed the site and its up, but you can't build a 2008 CTS, everything is still 2007 models.
