Question to Engineering types: Is this a RWD chassis??
This doesn't look like a W-chassis or a Sigma, it's too big to be an Espilon, and it's not a Truck:
http://wieck.com/public/*2PV_052074
What is it? Anyone??
Re: Question to Engineering types: Is this a RWD chassis??
Looks like an exhaust tunnel. You can also see how little space there is between the spare tire notch in the trunk and the backseat floorpan for a drive axle. Additionally, there is no place to mount a transmission crossmember, and if you look at the spacing up front, it appears to be a FWD engine cradle.
Other "did you know" points:
- The display behind him reads "A new offering in the industry's largest segment" "The new Malibu will hold ..."
- There is a blue Malibu off to the left in the background.
- Going by a different picture, the chassis off in the background on the right is also a Malibu.
So it is my guess that the chassis on the rotisserie is also... a Malibu.
Looks FWD or AWD to me. There's no clearance in the tunnel for a transmission. Also note the mounting point for struts, where as I'd expect GM to do something with an SLA setup for a RWD platform.
GM was doing that type of massive hydroformed rail in a unibody back in the 1st-gen Aurora. In this particular case, I wouldn't be surprised if they're used in anticipation of a drop-top model.
Originally posted by Chris 96 WS6
Well, those don't look too massive to me first of all, and I thought C5 was the first to use hydroformed rails?
Not trying to be nit-picky, just trying to clarify.
Wouldn't that make these cars technically the same?
Originally posted by formula79
Isn't there a difference? I thought the C5 was technically body on frame with the hydroformed frame rales...much like teh Trailblazer and Canyon?
