Obama Unveils Fuel Savings Plans for Big Rigs, Heavy Duty Vehicles
Old Aug 9, 2011 | 04:21 PM
Slappy3243's Avatar
Exclamation Obama Unveils Fuel Savings Plans for Big Rigs, Heavy Duty Vehicles
I don't know if now is the best time to announce something like this.
http://www.dailytech.com/article.aspx?newsid=22394
Big rigs need to cut fuel consumption up to 23%
Having high fuel efficiency in a vehicle is a great thing for the driver because they can spend less on fuel. Having higher fuel economy on vehicles across the automotive market will reduce the need to import foreign oil and will help to reduce overall pollution as well. The big downside is that the cost of the tech to improve fuel economy is not cheap and that cost will be passed onto the car buyer.
The Obama administration today outlined its Heavy-Duty National Program [PDF] fuel economy standards for heavy-duty vehicles like semis, concrete trucks, dump trucks, and other heavy work trucks. Rather than targeting a specific mile per gallon rating for the heavy-duty vehicles – like what has been proposed for passenger vehicles -- Obama is going to target a percentage of fuel savings.
The reason for this significant difference in fuel savings is according to the administration imposing a MPG standard on this sort of vehicle would be very confusing considering that the range of categories is wide and the payload and duties in the segment vary widely.
The administration wants a 9% saving in fuel consumption and greenhouse gas emissions for work trucks (fire trucks, garbage trucks, and busses, etc.). Gasoline swilling heavy-duty trucks and vans will need to see a reduction of 10% with diesel versions needing to see a 15% savings. Big rigs have the most stringent cuts at up to 23%.
The regulatory announcement also makes the following claims with regards to recouping the added cost associated with adopting more fuel efficient technologies:
Using technologies commercially available today, the majority of vehicles will see a payback period of less than one year, while others, especially those with lower annual miles, will experience payback periods of up to two years. For example, an operator of a semi truck can pay for the technology upgrades in under a year, and have net savings up to $73,000 over the truck’s useful life.
The new standards will apply to covered vehicles in the 2014 to 2018 range. The hope is to cut 530 million barrels of oil consumption and $50 billion in fuel costs over the life of the vehicles with the new standards in place.
The cost to meet the new standards on the varying vehicle types are expected to be in the range of hundreds of dollars to thousands of dollars per vehicle.
Old Aug 9, 2011 | 05:14 PM
Koz2's Avatar
Re: Obama Unveils Fuel Savings Plans for Big Rigs, Heavy Duty Vehicles
I'll plead ignorance here, but I have to imagine that if it only costs "hundreds" of dollars to improve the fuel economy 9-23% on these vehicles (which already cost at least what, $50,000 and probably easily climb to well over $250,000) that it would have been done by choice years ago.
Old Aug 9, 2011 | 06:03 PM
jg95z28's Avatar
Old Aug 9, 2011 | 08:41 PM
R377's Avatar
At the same time, they ratchet up the emissions requirements, which are often at odds to fuel economy and certainly to power.
Fact is, if the manufacturers had the know-how to increase efficiency that much for big rigs, they would have. Fuel is the number one cost for long-haul trucks, and any net cost advantage they could offer the market would gain them tremendous market share. It's not like consumer cars, where people are willing to sacrifice some fuel economy for luxury or performance and therefore sometimes the government needs to step in to rearrange priorities ... with big rigs, fuel economy already is the number priority.
In other words, if such gains could be gotten, they already would have been.
Old Aug 9, 2011 | 08:51 PM
5thgen69camaro's Avatar
This...
Old Aug 9, 2011 | 09:18 PM
OutsiderIROC-Z's Avatar
Seems more than logical to me as well.
Old Aug 9, 2011 | 11:27 PM
formula79's Avatar
Yeah..emissions and gas milage seems to really be at odd on diesels. Every since they add the DPF and Urea to new diesels, gas milage has fallen.
Old Aug 10, 2011 | 05:13 AM
Koz's Avatar
Koz
Do you think it's because of the addition of the DPF and urea injection, or that those just coincide with calibration changes that were geared more towards emissions performance than engine efficiency/fuel economy?
Old Aug 10, 2011 | 06:10 AM
96_Camaro_B4C's Avatar
The addition of diesel particulate filters alone (as happened with the EPA07 diesel regs) did hurt mileage somewhat because fuel is used to "burn off" / regenerate the particulate trap. However, SCR allows the engine to run in a NOx-heavier region (making less particulate / soot matter), because the NOx can be catalyzed downstream, so the 2010+ engines that have both DPF and SCR are seeing some mileage increases. At least in the heavy duty world.
In the pickup world, since they keep adding more and more power and torque, I'm not sure where the numbers fall.
Old Aug 10, 2011 | 08:49 AM
Geoff Chadwick's Avatar
This might not be so bad, depending on how it's put into practice. For example - there are already class 5-7 hybrid trucks that can get some pretty swank fuel economy depending on application (the hybrid system is designed and built by Eaton's Roadranger line) and I'd bet they'll already meet the new regs.
Next, a lot of manufacturers can use this as an excuse to cut out the long nose flat hood trucks (which have terrible economy!) where they blamethe govt for ditching them and can save some face. Then I bet this would apply to vehicles "as configured", meaning you drop you 15L engine for an 11.9L and go from a 10 or 13 speed to a 17 speed. That'll get you a bit more. Automated transmissions are vastly superior when working with the engine controller and they're still not widely accepted.
Add skirts/flaps between the trailer and cab and between the trailer and the ground, add an aerodynamic "bubble" on the back of the trailer, add fenders over the drive axles, and make sure every truck is a full fairing truck..
Oh and use the govt mandate for better brake distances to go all disc that'll help out a bit too.
Then put a small APU on the rails for hvac/power when the truck is stopped so they don't have to run the engine at a truckstop (as apus are not part of the regulations).
I could see manufacturers wanting this where they distinctly DIDNT want to add SCR systems for 2010. There are long haul trucks out there that can get 8-9 mpg...
Old Aug 10, 2011 | 09:03 AM
Zigroid's Avatar
they call it a fuel savings plan.
what exactly is their plan for manufacturers to increase fuel mileage? tell the manufacturers that they need to do it then sit back and fine them if they dont reach the stupid goals?
my dad works for a major truck manufacturer. they try and get every last drop of fuel out of a mile. the government having this miraculous "plan" isn't going to do **** its just going to **** everyone off.
I just don't get their ignorance.
Old Aug 10, 2011 | 01:59 PM
94Camaro_Z_28's Avatar
This douchebag has the answer to everything, doesn't he?
Old Aug 10, 2011 | 02:13 PM
94LightningGal's Avatar
It is very easy for those, who are not in the trucking industry, to talk about how easy it is for the trucking industry to do something. The reality being, fuel is one of the most expensive aspects of the trucking industry. Anything "easy" to improve it, was done a long time ago.
If you want to eliminate the standard conventional tractor, who is going to pay for that?? Do understand that most tractors have a lifespan of many millions of miles. Also understand that a large part of the truck driving fleet is owner operators. These are people who own their own tractor, but not their own trailers. Most of the time, they pick up the loaded trailers from whomever they get the haul from, and deliver it to where it is going, and move on to the next. The vast majority of these people run conventional tractors.
Do you plan on paying them to replace their tractors with a new, $200K model?? Do remember that they have to live in their tractors also. When working, it is their home, and the average truck driver is on the road 25+ days a month.
Also, understand that there are probably millions of trailers out there. How much money do these companies have to spend, to put skirts on all of them?? To put APU's on all of the tractors?? To put all of the other aerodynamic skirting on everything?? How many billions are we talking about?? Or, are you advocating that all older tractors become illegal, forcing owners and companies to replace them all, with new, more efficient models??
Projections of fuel savings are BS, due to the replacement times for most tractors. The price of a tractor is amortized over a huge expanse of time and miles. It would literally be decades before they would all be replaced with newer, more expensive, less reliable but more efficient tractors.
How much money are you willing to pay for all of the goods you buy, for the trucking industry to eventually realize much of a fuel savings?? This would truly be a pay me now, and eventually I will give you a benefit.
What regulations like this do, is slowly squeeze out the independent owner operators, as it makes it more and more prohibitively expensive to operate on their small scale. You have no idea the 100's of thousands of people this could potentially put out of business. Any regulation that is anti small business.................. who employs the vast majority of people in this country................ should not be allowed to happen.
Ride one week in their footsteps, and then tell them how easy this all is.
Old Aug 10, 2011 | 02:30 PM
SSCamaro99_3's Avatar
I am going to admit to some skepticism here. Documentation, comparisons, design alternatives?
Old Aug 10, 2011 | 02:51 PM
The Volvo aero tractors have had very limited penetration in our market. Truck drivers like the standard conventionals because they look better, ride better, and are easier to drive (you can see the corners and edges of the tractors, which is imperative to manuvering a huge tractor trailer................... where sometimes you are dealing with an inch or two between getting through unscathed, and disaster).
Some may scoff at drivers who care about how their tractor looks, but I will ask you this: Do you care about how your home looks?? Would you purchase a hideous (to you) home that cost alot more, but promised more efficiency?? Heck, do you purchase a car that you can't stand the look of?? What about if the government said that due to increased household efficiency standards, you have to buy an ugly house with a low ceiling, that you had to stoop over in, to change your pants. Oh yeah, and you get the bonus of much higher initial cost, and much higher maintenance (ask a few drivers with newer tractors about this).
Would you be jumping up and down for joy??
