New Piston Ring Could Drastically Improve Gas Engine Efficiency, Longevity
Old Aug 22, 2010 | 02:15 PM
Slappy3243's Avatar
Thumbs up New Piston Ring Could Drastically Improve Gas Engine Efficiency, Longevity
http://www.dailytech.com/article.aspx?newsid=19406
Traditional gas engine piston rings with a diamond performance coat (it's a bit hard to see, but note the untapered surface) (Source: Speed Engineering)
Federal-Mogul's new LKZ ring tech is old hat for diesel engines, but cutting edge for gas ones. It offers a tapered surface and inequal downstroke/upstroke pressure profile. All this means better oil distribution leading to better fuel efficiency and better engine life. (Source: LKZ)Tiny change to engine could offer better lubrication for a more pleasurable experience
Think the standard gas engine can't measure up to hybrid vehicle performance? A new gasoline engine breakthrough, along with recent innovations may invalidate that premise.
Admittedly, gasoline automobile engine at the turn of the millennium was disappointingly inefficient. While there had been great advances in digital control and performance tuning, the base efficiency of the engine proved only slightly improved from designs of two decades prior.
Today that's starting to change. There's two basic schools of thought. One is to adopt a radical redesign, going for technologies like electric motor-driven hybrids or full-electric vehicles. The other approach, equally promising, is to keep the gas engine, but to reevaluate every engine part and their operation.
Companies like Ford have enjoyed great success with this approach, employing engine technologies such as direct fuel injection and turbocharging to milk V8 performance out of a V6. Now a breakthrough in the oil rings that line the cylinder head in gas engines and keep it lubricated with engine oil may allow even more impressive performance on a gas-burning engine.
An engine parts supplier called Federal-Mogul Corporation has managed to adapt a specialized two-piece oil ring design from diesel engines into a gasoline engine form. The patented oil ring tech, known as an LKZ ring, not only can reduce oil consumption by 50 percent, but also reduces frictional losses by 15 percent (compared to standard conventional oil ring designs).
Where as traditional rings apply equal pressure on the downstroke and upstroke, the new ring design primarily provides pressure on the downstroke. The surface inside the piston bore also employs a unique design, offering a tapered, two-step surface (versus an untapered surface in standard oil rings).
The result is that oil is more effectively returned to the oil pan, reducing the amount of oil that enters the combustion chamber. The less oil entering the combustion chamber, the better, as this has numerous undesirable effects, such as wasting oil via combustion and coating the spark plugs with carbon byproducts, reducing their ability to combust gasoline. The improved oil performance also leads to better cylinder lubrication and less friction.
The rings are available to enginemakers with a variety of coatings, including chrome, CKS (chrome ceramic coating) and GDC (Goetze diamond coating). By selecting the right coating, engine makers can match the rings to their engine's intended performance profile, ensuring longevity. For example, a more powerful engine would necessitate a hardier coating to ensure that the ring remained undamaged under intense mechanical forces.
For engine makers looking for the ultimate in performance tech, Federal-Mogul says it will offer the new ring design with its patented DLC (diamond-like carbon) coating, which offers the least engine friction, while offering a long lifetime.
It would be truly exciting to see these new LKZ rings end up in a bleeding-edge mass market gas engine design, such as Ford's Ecoboost engines. It could perhaps offer an additional 5-10 percent (at least) additional extension to fuel economy out of an affordable and easy-to-deploy component upgrade.
I don't know much about piston ring technology, but it seems pretty cool that small improvements are still being made.
Old Aug 22, 2010 | 02:48 PM
Silverado C-10's Avatar
Very cool.
But this part just made me laugh, I mean seriously, this had to have been put in on purpose
Old Aug 22, 2010 | 05:24 PM
Slappy3243's Avatar
Originally Posted by Silverado C-10
Very cool.
Ha, yeah. I was going to bold that part but I forgot. The guy who writes these articles always leaves an innuendo like that .
Old Aug 23, 2010 | 11:08 AM
WhiteHawk's Avatar
Usually the oil groove has sandwich of three rings. If they are only using one to retain the oil ring in the groove, then that is a big change (based on the picture).
-Geoff
Old Aug 23, 2010 | 09:13 PM
Koz's Avatar
Koz
While this seems promising, I'm extremely skeptical about any 5-10% fuel economy increase.
Old Aug 23, 2010 | 10:03 PM
bossco's Avatar
I wonder what context they were using the fuel economy increase in? 5-10% for the engine or 5-10% for the vehicle? Fuel economy does seem to imply a vehicle though and that does make it hard to beleive that ring drag would have that much effect. On the otherhand, maybe a 5-10% increase in the engine's effciency wouldn't be out of the question.
1963SS
Feb 6, 2015 10:05 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
RichJ
Sep 26, 2002 09:43 AM
simple
Aug 11, 2002 11:56 AM
