Needs sources for cost to assemble various engines.
Old Feb 24, 2006 | 01:38 PM
RussStang's Avatar
I know this has nothing to do with the Future Automotive Section, but I also know many of the guys here are in a better position to answer me then the guys in the lounge, so here is my question.
There is a little debate going on over at ls1tech.com about the cost of a pushrod engine to assemble then the cost of its DOHC equivalent. What I am looking for is some actual numbers to use in the arguement that the pushrod engine is cheaper to produce; something besides just heresay. Any help on this would be appreciated.
Old Feb 24, 2006 | 02:55 PM
2MCHPSI's Avatar
Re: Needs sources for cost to assemble various engines.
I assumed it is common knowledge that pushrod engines are cheaper to produce. A simple google search will show many different articles doing a comparison of the two types always use the cost as a major factor in the differences. Pushrods always being cheaper.
If someone believes OHC is cheaper, then that is their problem.
Old Feb 24, 2006 | 08:31 PM
WERM's Avatar
Where's the debate?
32 valves > 16 valves
4 cams > 1 cam
Old Feb 24, 2006 | 10:59 PM
RussStang's Avatar
You would be suprised how much trouble I am having discerning direct costs for various engine productions.
That doesn't go over too well in an arguement though. I need some more concrete info.
Old Feb 25, 2006 | 10:38 AM
HAZ-Matt's Avatar
Originally Posted by WERM
Where's the debate?
4 cams > 1 cam
Ha exactly. Look at the relative masses and parts if you can't find anything else.
Old Feb 25, 2006 | 11:34 AM
SSbaby's Avatar
Less cams, valves, springs although OHVs use pushrods which DOHCs don't have.
Don't forget, for DOHCs, there's two relatively expensive (and heavier) heads that go into a V configuration engine... that adds weight to the top end of the engine. That being the case, DOHCs also have two cam phasers if they run VVT.
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
