Most fuel efficient automakers
The way they define different models is retarded... Chevy has 88 vehicles?
These stats really make no sense. Just an average of each model with an identical weight given to each?? Stupid.
How about separating them by class and then averaging each class or even giving us a vehicle by vehicle run down segmented by class? Or maybe by sales numbers? I mean something of significance other than by model variants by name.
Nice. You hit the nail on the head with that one. Although in fairness to Chevrolet. They probably have more truck models than car models if they count every trim level of every regular, extended cab, crew cab etc. So those would hurt them.
So, are the brand averages a function of volume-weighted averaging (like CAFE), or did someone just go through the EPA fuel-economy handbook and do a simple average of each model's rated economy? The first method is fairly meaningful, while the latter is nearly worthless.
Besides, how do you then explain Pontiac and Saturn? I've been saying for a while now that GM ought to take advantage of the fact that both these brands are known for selling cars, not trucks.
And I'll agree with Eric that they need to somehow weight the volume of each model. It wouldn't make sense that if (for example) Chevy sold only one variant of pickup truck that got 18 mpg and sold 750,000 units, that it would have the same weight as a niche variant of a Cavalier that gets 35 mpg.
Originally Posted by From the Article
Several carmakers boast higher fuel economy with the automatic transmission than with a manual (if available).
It seems that many manufacturers are putting manuals with shorter final gearing than their auto counterparts. Honda is doing this across a big part of their line (I don't think Civic, though), and it makes the whole notion misleading.
For instance, my TL- in auto form, final drive in 5th is 2.11, providing about 2000rpm at 68mph. With the manual, final drive is 2.53, providing 2000rpm at 60mph. With that sort of deviation (which is the same in the TSX), it's easy to see why the manual can't beat the auto under these conditions.
I'm guessing that they're doing this to either-
1. make the car feel "peppy" as compared to the auto.
2. reduce low-RPM loading to reduce engine lugging possibility and/or NOx emissions.
In any case, it's weak. Stick cars with equal gearing would pick up 1-2mpg easily. I have both a 5spd auto TL-S (2002) and a 6spd manual (2006), and the manual kills the '02 in city driving. Like a solid 3mpg better over a few thousand miles logged.
With a company like Chevy having several different models of trucks and Mini having none, how does Chevy get a fair shake?
Separate "cars" and "trucks" if you will - but without weighting the results with the fleet production volumes, there's no meaningful information to be found in averaging the EPA numbers.
