LS7...not so good
Re: LS7...not so good
Originally Posted by Hoodshaker
There are many benefits to the Hypereutectic piston but if you look at the design of the engine, WEIGHT was probably the #1 factor in the decision. They are considerably lighter than a forged piston would be. Can anyone think why that might be important on a 427 cubic inch engine that spins to 7K?
You'da thunk them thar' city slicker college boy injuneers coulda dun figgered that out by now if they wern't so bizzy playin' with them fancy tella-scope-thinga-majiggers and buildin' motors like cousin Darryl does! Knowhutimean?
Originally Posted by graham
The deal with the forged pistons is that cast pistons (hypereutectic or not) have an offset pin bore to minimise noise on cold startup. That's why they have a dot on top to indicate the front of the motor. Forged pistons can be put in either way as long as the valve reliefs are symmetrical.
The "piston slap" we speak of in this thread has notihng to do with that. Chevy is just a lil inconsistent with its finish hone and there is just a fuzz too much cyl wall clearance until the piston gets a lil heat in it and expands a fuzz. No biggie actually.
I've met probably no less than 20 GM vehicle owners that hear a little lifter chatter and say that its piston slap. When they just really need to change their oil filter more frequently, lol. Some fools even hear the "click" of the injectors and think something is "ticking" inside the motor. lol
Its also my understanding that a forged piston can make life hard on a knock sensor too but i dunno...
I have piston slap constantly, it just goes away some when the engine is warmed. It is still there though, it isn't that hard to hear. This is something GM knows about, and I am sure they are trying their damnedest to make sure their $70,000 car makes no engine noise whatsoever, cold startup or otherwise. I don't know if this is the reason why their are cast pistons running in the LS7, but I wouldn't put it past GM, given how notorious these engines are for making noise.
I don't think cost had much to do with piston selection, if at all. The engine has lots of exotic parts that are not cheap, and I don't think they skimped here. There are many benefits to the Hypereutectic piston but if you look at the design of the engine, WEIGHT was probably the #1 factor in the decision. They are considerably lighter than a forged piston would be. Can anyone think why that might be important on a 427 cubic inch engine that spins to 7K? Those are very large pistons to sling around at that rpm...
Also, how would you protect such a exspensive roatating assembly from stupid people and wanting warrenty work on the motor after it blows?
But, I have to say that the weight thing probably had more to do with the decision. Kind of funny, I'm sure if this was in a BMW people would think it would have been a fluke, but IF this is true, then it is just another piece of cramp from GM.
Originally Posted by mastrdrver
EXACTLY!
The specific density of the materials is close, and as long as the cast part has no voids (which have a good chance of causing catastrophic failure and are a problem the forging simply doesn't have), the difference in density is offset by the fact that the forged piston can be designed with thinner walls due to it's inherently higher yield and ultimate tensile strength.
I'm not buying without better information, so please support your position with some data or other evidence.
Here's a little blurb from a performance company on the issue:
"There are disadvantages (to cast pistons) also, of course. The piston will be weaker in structure. It is often heavier since the manufacturer has to increase wall thickness in order to achieve sufficient strength. The heat expansion cannot be controlled and is therefore often not completely round since the piston pin requires some material on the inside. They are also produced in bulk with most manufacturers only producing sizes that are close to factory specifications. This also makes them more affordable."
Originally Posted by PacerX
Why exactly are you asserting that a forged piston has to be heavier than a cast one?
Hypereutectic alloys are also slightly lighter (about 2 percent) than standard alloys. But the castings are often made thinner because the alloy is stronger, resulting in a net reduction of up to 10 percent in the piston’s total weight.
Remember we aren't talking about standard cast pistons vs forged, we're talking about hypereutectic pistons which contain at least 12.5% silicon for additional strength, less weight, better expansion/contraction properties which allows tighter tolerances for less noise, less blow-bye etc.
Originally Posted by 30thZ286speed
This whole thing is more than likey more rumors than facts
In other words, such information would come across as first hand... not innuendo.
Originally Posted by thesoundandthefury
Forged pistons are noisier than hypereutectic. I'm sorry, it's just reality. Yet you said yourself that the piston slap in your LS1 left you with the impression that it was an "inferior" engine to your LT1. Do you honestly think that GM didn't take this into account when they built the LS7? Does it make sense that they would utilize a piston who's level of noise production could be mistakenly perceived as being the same condition found in the LS1, and therefore risk the impression of it being an "inferior" engine? Read between the lines.
Lemme break this down even further. If you had to choose between two "bad impressions" that the car you're building would go down in history as being known for, which would it be:
-Couldn't run NOS without changing the pistons
or
-A $70,000 Corvette with an engine that sounds like it came out of a $25,000
Camaro
or
Camaro
Noise was never a problem in my 5.0s, Ford's Mustang Cobras seem to have been able to make forged pistons that don't clank when cold, and my SC (outside of slight supercharger whine and Ford's typical noisy power steering pump) doesn't make a racket, so I don't buy theForged Pistons=Piston Slap school of thought.
Frankly, I know I'll never buy this Corvette or it's engine, even if I had the money (I feel the regular Corvette at 45K is a superior bargain to a $70K one....is it worth $25K over a regular Vette?!
), so on a practical basis, the LS7 pistons could be made of glass for all that affects me.
Read that and more here http://www.aa1car.com/library/2003/eb40354.htm
The example above from the article is addressing cast hypereutectic vs. cast eutectic, and doesn't address forgings at all.
A hypereutectic cast piston is decidedly inferior to a forged piston of suitable material from a strength standpoint. Casting does not provide the grain control of forging, regardless of alloy.
Wait a second here, your example is flat-out wrong.
More on the subject that speaks directly to cast vs forged. http://www.glmmarine.com/castvsforged.html
The major disadvantages to forged pistons are actually a result of the forging process itself. Forging results in a piston that is considerably heavier, than cast pistons, and is limited in the aluminum alloys that can be used to produce the piston. Additionally, the forging process also limits the design configuration of the piston itself.
Cast (regardless of post-processing and metallurgy in the case of common piston materials) is less expensive than forged.
Now, the guy that sprayed the car and blew up his motor got what he deserved, and in no way is GM responsible...
BUT...
... all in all I think the inclusion of hyper-u-explode-it pistons in the LS7 is major failing on the part of Powertrain. There will be all kinds of reasons one way or another, and certainly trade-offs (expansion and noise come to mind...), but the overriding goal for the LS7 MUST BE a bullet-proof short block. Forged pistons are the way to remove a possible weak link.
BUT...
Nothing at all "wrong" with the LS7. If you haven't driven a car with the new LS7... which I have... then allow a little room for doubt about "issies" in this foolishness.
