Impala SS Goes 0 to 60 in 5.6 and to a Top Speed of 154 mph!
Old May 1, 2006 | 06:33 PM
  #16
teal98's Avatar
Re: Impala SS Goes 0 to 60 in 5.6 and to a Top Speed of 154 mph!
Originally Posted by CLEAN
I guess I should have prefaced it w/ saying that the negatives on the car are in a realm that 95% will never be driven in. I mean for what the car is, even in SS trim, how many people are going to be pushing it's handling limits?
You don't have to push it to its limits to notice negative FWD characteristics. If those characteristics don't bother you, then the Impala SS is a good choice -- a little faster and better mileage than the Charger RT.
When I read a C&D road test, I always apply the filter of things that I care about. The fact that they report on things I don't care about doesn't imply to me that they shouldn't report on them, because others surely do.
The magazines used to complain about the live axle on the Camaro too -- especially when the writer was an import bigot. I generally don't mind a little bit of rear axle dance anywhere near as much as FWD torque steer or FWD wheelspin. So I ignored the complaints and bought a Camaro. However, the magazines wouldn't be doing their job if they didn't comment on it.
Old May 1, 2006 | 06:49 PM
  #17
CLEAN's Avatar
Fair enough.
Old May 1, 2006 | 07:49 PM
  #18
formula79's Avatar
Originally Posted by 30thZ286speed
I wonder why the Impala SS is unlimited on top speed and the GXP is limited to 143 mph. And why the different axle ratios, the Impala SS gets the more aggressive 3.29, One would think the GXP would get the same but its got a 2.93?
GXP crosses the 1/4 in 2nd gear....I am not sure about the Impala. It is quite an off experiance going 102mph in second
Old May 2, 2006 | 08:40 PM
  #19
MagnaPilot's Avatar
This link here at clubgp.com says the SS/GXP tranny has a 3.29 final drive, but a 2.93 effective. Now normally I can understand this, but today I'm tired and don't quite understand which is which. It also never makes mention of there being a SS and GXP version, though I may have overlooked that. Qhat do you guys think, can someone explain this to me?
http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
4T65E FWD Transmission Content for Gen 4 V8 (LS4) Application:
- 258mm, RI 15 Torque Converter
- Enhanced Heavy Duty 3.29 Final Drive
- 2.93 Effective Final Drive
- Transmission case for transmission mounted starter
- Net-formed Input Sun Gear
- Ceramic bead Peened Final Drive Sun Gear
- Input/Reaction Carrier Assembly
------ Contour Hardened ReactionInternal Gear
------ Input Carrier & Gear Asm. with lube grooves
------ Shot-peened, Black-oxided Input Carrier Pinions
------ Shot-peened Reaction Carrier Pinions
- Shot-peened Final Drive Sun shanft
- Upgraded Drive sprocket Thrust washers (new for high speed capability)
Old May 3, 2006 | 07:10 AM
  #20
Jason E's Avatar
I read the article, and one thing it did say was that the W body had been significantly revamped since its inception, "and those changes have been beneficial."
It doesn't sound like they were acting like this is an 18 year old chassis. They complained about the torque steer issue, and the fact it does have a lot of body lean. It does have both, more so than the GXP. End of story, I guess. One thing that did annoy me is both them and Edmunds said the car is "happier" with the 3.9. To me, that makes no sense. An LTZ will lean more than an SS, and if you don't like torque steer, don't nail the crap outta it all the time! The SS can be just as happy as the LTZ, IMO...
Old May 3, 2006 | 09:04 PM
  #21
teal98's Avatar
I think the theory is that the 3.9, being lighter, will make for a better balanced car (as in less front heavy) with less understeer. It's the same reason that the smallblock V8s were often preferred in the Pony cars back in the 1969-70 timeframe. For example, you could get a 383 or 440 in the 1969 Barracuda, but the 340 made for a better balanced car. Or at least, that's what the road tests of the era said.
Old May 4, 2006 | 07:24 AM
  #22
Jason E's Avatar
But, I don't think the 3.9 IS lighter...I think they weigh about the same. Remember, the 3.9 is an iron block, the 5.3 is alloy...that makes up a ton of difference...
Old May 4, 2006 | 05:07 PM
  #23
teal98's Avatar
Did the Impala gain that much weight? The 2005 model weighed more like 3500 pounds, and that was with the Iron 3.8. The car in C&D's test weighed over 3700. I'll bet the 3.9 puts less weight over the wheels even if the engine is the same weight, because the rest of the drivetrain can be lighter.
The other possibility is that C&D just felt there was too much power for the chassis. That was my impression in a very brief drive, though you could just put a brick under the gas pedal
Old May 4, 2006 | 10:00 PM
  #24
formula79's Avatar
The GXP is a great package....if only I could get better gas milage
Old May 5, 2006 | 12:54 AM
  #25
teal98's Avatar
A good reason for the brick under the gas pedal?
Old May 5, 2006 | 09:50 PM
  #26
stereomandan's Avatar
That is an impressive trap speed. Better than I thought it would get. Good job GM for that. Not a lot of daily drivers trap anywhere near that high. Too bad that it sounds as though it looses out on the handling, and throttle control category.
I've never been a fan of the latest Monte Carlo body style ever since it looked like a Nascar vehicle driving around town. Lots of chicks seem to like it though. It seems easily 50/50 male to female ratio.
Dan
Old May 5, 2006 | 11:29 PM
  #27
smooth3d's Avatar
Let me ask you this can the GXP parts be put on the Impala SS to improve handling?
Old May 5, 2006 | 11:42 PM
  #28
steves's Avatar
Everything is a direct bolt on if you look on Club GP you will find all the part numbers. There is a list in the 2004+ section. Save a few grand and get a fully loaded GXP.
Old May 6, 2006 | 12:02 AM
  #29
Speed_Kills's Avatar
No Rwd = No care
Old May 8, 2006 | 11:34 AM
  #30
Bert02SS
Guest
Posts: n/a
Originally Posted by Speed_Kills
No Rwd = No care
QFT.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
canbaufo
Feb 24, 2015 10:27 AM
NewsBot
Jan 11, 2015 06:10 PM
mark0006
Dec 25, 2014 09:50 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
