GTO vs Charger SRT-8
Re: GTO vs Charger SRT-8
Originally Posted by guionM
On my way out the house, so I'll make this quick.
2. The SRT-8 stickers as much as a GTO. Forget about whatever deal you made. Both are going for the same price. I'm very glad some of you saw a GTO in the paper for $19K after incentives, dealer pay back, and an act of God, but real world price is now $35,000. No current incentives.
Wrong
Originally Posted by GN1270
You would lose your *** then. No torque mgmt in the 05. I do not beleive any 06's have hit the lots yet. I bring the CTS-V into it becaue it is a 400HP LS motor that is faster than the GTO and I owned one so I can compare the V's performance to the 300's. Also you may want to take a look at this. http://motortrend.com/roadtests/seda...rio/index.html
As for what you can do with the $10k you save with the GTO, You can try to see if you can purchase 20" wheels and tires, Huge Brembo brakes, 25 more HP, a new warranty, a DVD Nav unit, a sunroof, rain sensing wipers, 2 more doors, a ton more cabin space, satellite radio, etc. A base Charger SRT-8 starts at $35k. I in no way want to flame the GTO's performance because I think it is worth the money, but to try to say the SRT vehicles are a rip off compared to it is just wrong.
Also, maybe you should do some research, but apparently you are wrong. This is the first thing I found when I google the torque management on the CTS-V, and I didn't look very hard. One of the guys in this thread was apparently pretty happy when he deleted the torque management from his car.
http://www.ls1tech.com/forums/showth...43#post3670443
LS2 = electronic throttle = no reason for me to believe that the Cadillac has it absent, even though the Vette, GTO, and SSR (and most likely Trailblazer) all have torque management straight out the factory door. Especially when the Caddy is using the same tranny as the Vette, SSR, and GTO. Doesn't make much sense, does it?
*Edit - Here is some more info how my *** would have been in quite good shape if I were to bet it
http://www.ls1tech.com/forums/showth...que+management
Originally Posted by teal98
By the way, is this ATCO the same track where GMHTP got an early LS-1 Camaro into the 12s? I've read that it's a very fast track.
According to the article they ran the Bullitt at Raceway Park, and they ran an Fbody to compare it to, so it is most likey they ran the Fbody at raceway park, in the heat.
1. The SRT-8 is QUICKER than a GTO.
It's not 12.56 but it's still in the 12's.
http://www.chargerforums.com/forums/...ead.php?t=3309
http://www.chargerforums.com/forums/...ead.php?t=3337
http://www.chargerforums.com/forums/...ead.php?t=3365
A quote from LS1 GTO forums...
And this quote from one of the above charger forums link...
So who and what do you believe? I know some people are not being completely up front.
Anyway there is a formula you could use to dispell a few myths...
See this link...
http://www.stealth316.com/2-calc-hp-et-mph.htm
ET = (weight/hp)^1/3 x 6.269
mph = (hp/weight)^1/3 x 230
hp = (mph / 230)^3 x weight (lbs)
hp = weight (lbs) / (ET / 6.269)^3
Sorry - I was there and saw it. I thought from your prior post JS1965 you were also.
First, I did not check the tires - but he was 2 lanes over from me - he sat their with about 30 pounds of ice on his manifold. Next, he went up to the starting line & cooked the sh*t out of his tires. Interestingly - it looked like he had a line lock on it (my son says that he heard the guy say he had racing radials on it - otherwise he said it was pretty much stock).
Something don't add up here - yes the car was fast - but was he stock - I don't think so.
The 300 next to him was mid to high 13's only - again per my son - who was there. We left by 11:30 so this car may have run quicker - was it Silver by any chance - if it was what a wuss - he brought out a feather duster in the stagging lanes to dust off his car. The other guys in the lanes were peeing in their pants watching it!
http://www.ls1gto.com/forums/showthread.php?t=47381
also it had 96 octain gas in the tank
See this link...
See this link...
See this link...
I know what I believe. I believe that an LS2 GTO has a very good shot at a Charger SRT-8 in a straight line run. I am not some GTO humper either, this is just the conclusion I draw from the information I have provided myself with.
Wow, I have never seen you so obviously wrong ever before. Kind of shocking honestly. I've seen 3 brand new GTO's for ~30k(can't remember the last 3 digits), and that is that. SRT-8's are far more expensive.
Obviously the Hemi is underrated from the factory as you said. I don't know what is so hard to see about that.
Well I don't know why the owner would want to run 96 octane gas if the Hemi is stock.
Running higher octane gas doesn't get you more power but it does safeguard against knock... but the factory Hemis should be running pig rich (as are the LS1/LS2s)... there should be little likelihood of knock in a stocky. Given the weather was cool, there would be even less likelihood for knock. Unless, of course, there's more to the story...
I wouldn't put it past a few runners to test some aftermarket development stuff for the Hemi either. Anyway, who's to say the guy wasn't running a strap on chip to enhance spark and lean out mixures? That's stock, right?
Originally Posted by falchulk
Most high performance engines now-a-days gain about 10hp or so by running on the high octane stuff. The computer automatically retards/advances the timing to avoid knock. It can do more if it's running high octane. The old argument of if the manual says run 87 you dont get anything by running higher is no longer valid. Actually, some manuals state the power will increase.
