GMT-900 time launch time table
Re: GMT-900 time launch time table
Originally Posted by redzed
Actually, gas prices seem to be moving downward.
You are right, and when you're right, you're right.
Yes, last night it dropped from 86.4 ¢ a liter to 82.9 ¢ a liter.
Can't argue with that.
More than a few of these points indicate that you aren't too well informed.
Nobody is offering a half-ton diesel. Why? It's just about impossible to produce a 50-state emmissions legal 1/2 ton truck - and pretty soon it will be completely impossible.
Another problem is the $4,000 to $5,000 cost of current diesels and the fact that you'd have to use a 3/4 ton drivetrain to withstand the torque of a modern turbodiesel. In short, a 1/2 ton diesel is pointless.
As far as the drivetrain goes, the new 6-speeds should have much higher torque capacities, and if needed, the 9.5" 14-bolt axle fits just fine (it's now used in the Silverado SS).
It's more of torque issue. For some reason, GM's pushrod engines seem to be less effective in producing torque than DOHC 4-valve engines. It seem counterintuitive, but it's true. Even the LS2 has a relatively low specific torque output for its displacement.
The LS2 has relatively low peak torque, but very good average torque. TPI-like powerbands have their place, but not anywhere that the LS2 is used.
To address Z28x's comments, note that I didn't say that more power was really needed. If you can't get the job done with the 5.3 in a half-ton, then you're trying to do the wrong job with the wrong tool. And yes, closer transmission ratios would help a lot. That big drop between 1st and 2nd in the 4L60E is a killer for a relatively peaky engine like the 5.3.
The 6-speed replacement is coming, but it's very late - not a good sign.
That is product that nobody designs quickly. If you'd ever so much as dropped the pan on one, you'd understand why.
I do agree that they should have started the project long before they did, however. Someone apparently thought that since 3-speeds lasted 25 years in the market, 4-speeds would live just as long. That type of thinking shows a lack of market leadership.
Is a Ford SuperDuty or Dodge Ram 3500 any better in this regard?
I wholeheartedly agree. However, the big problem is that the GMT-800 doesn't seem to have large enough wheel wells/openings to accomodate appropriately sized tires while maintaining appropriate levels of wheel travel.
Dodge is filling this tiny niche market very adequately. A live front axle has it's place, but I really don't think that it should be on every 2500 and up truck.
Also note that Ford also has 'em, stock, on the Superduty. Combine SD and Ram HD sales and I think it's something more than a "tiny niche" (that phrase more accurately describes your understanding of the truck market).
I personally like IFS, but I don't plow snow (at least not with my truck - I've got other equipment for that task). For those that do hang a snowplow off the front of their truck every winter (which is a lot of people), a solid front axle is very desirable. I think GM would be able to gather additional sales in the commercial market by offering a solid front (it's available on the 3500HD model, but only as a 2WD).
Well, I have to completely disagree. You've forgotten that the 1999 vintage GMT-800 was a very slim improvement on its 1988 vintage predecessor.
If you're not a full-sized SUV buyer, you're opinions on the subject aren't worth too much? Are they?
Now, go out and buy a minivan.:LOL:
Maybe GM should have put more content into the Tahoe instead of wasting money on a surefire money loser like the Cobalt.
Lets see, the Cobalt is selling extremely well to people that want a good, dependable small car and the supercharged SS is getting praise from all the performance auto mags (even the import biased ones!). So GM is getting sales and good publicity. Man that JUST SUCKS. WHY WOULD GM EVER BUILD THIS THING!?!
Originally Posted by Eric Bryant
GM's minivans sucked before the half-assed makeover, so obviously they ended up sucking afterwards, too.
Originally Posted by Z284ever
They really needed the full-assed makeover.
as for the pontiac, buick variants....not even necessary
I also don't know what precisely initiated your ever-so-slighty angry response?
You admit that you aren't in the industry, yet it appears to me (and others) that you think you have have most, if not all, of the answers to the industry's problems...specifically GM's problems.
Day by day, I see this board becoming more and more psychotic due to the endless spouting of "facts" that are, indeed, only opinions based nothing in fact.
Some have called you a troll. I'd like to think you aren't and that you are intelligent enough to listen to others' opinions based in fact and perhaps learn something.
I guess I'm asking you to think through things and check your facts before coming out with outlandish thoughts and ideas.
I've said it before and I'll say it again.......the Camaro (and Firebird) brought hundreds of thousands together........and it bothers me that some would like nothing better than to divide. (not accusing you of that, but the net result is that, intentionally or otherwise, that's exactly what you're doing.)
Diesels don't cost an additional $5000 - there's a huge amount of market premium baked into that price.
To be realistic, a modern turbodiesel shouldn't demand much more than a $1,500 premium in MSRP.
I said van, not minivan - there's a difference. A GM G-van has a hell of a lot more utility than any SUV. If you disagree, let me know if you can roll a sportbike up into the back of your Armada.
The Mercedes-based Dodge Sprinter is interesting for it's diesel economy and huge load capacity, but it's far too expensive and far too tall for my garage.
Originally Posted by Red Planet
Quite frankly, your posts are, for the most part, opinions with little, if any fact/s to back them up.
Well, I'm not a GM employee or shareholder. I have absolutely no conflict of interest when I talk about the automotive industry.
No kidding!
Been there, done that. These days, there's no way I'd touch a traditional full-sized van with a 10 foot pole.
The fact that the Cobalt is produced at an actual American assembly plant is meaningless to this car's low-end demographic.
OK...I give up.
RedZed.......love ya, mean it......but WHERE do you come up with these things? Did you perchance take a poll? Perhaps you need to get out and get around this great country of ours....it is not meaningless to a lot of people.
Jeez.....I try to get along with all my fellow enthusiasts....but you would try the patience of a Saint.
I've seen more than a few transformations in the style and content of your posts. I know what the current agenda is. I'll just accept your remarks at face value, even though I'm well aware of the context.
I will say this: I tried to remain as professional as possible...but at midnite, after reading through several different sites...and then logging onto this one...and seeing the outlandish behavior here, I do lose my patience. Shame on me! (you'd be surprised ...well, mebbe not....to see some of the things I've typed.......then read......and hit the delete key.....) (and then replaced the very damaged keyboard......)
But I invite you to elaborate (especially the 'agenda part!) Seriously.
Scott,
Don't waste another keystroke on this troll.....seriously, his "agenda" is to stir up c r a p to bring attention to him/her/itself....heck most threads in the last few days have been aimed at putting this troll in his place.
He/she/it is an obvious attention w **** and not worth another post.
In nearly every instance, I have chosen to ignore the pathetic attempts at simply being a bore....I've given in when it gets too stupid, but then that's the game here.........damn everything GM does just to be a troll.
Fug it......let's just all put him/her/it on our ignore list and get back to an adult, constructive debate.....
