GM Fuel Economy Observation
This is what I hate about the US... *if* GM did that, then the car would get ragged on by every magazine under the sun for being slow, lathargic, not fun to drive, etc... and some how, because it's not a foreign name plate, the "slowness" will get attributed to "low quality."
That's what is really frustrating about their choices. Stick a 6-speed auto behind the latest AFM 3.9 to achieve 35+ mpg (highway) in a full-size Impala and a powertrain that is significantly cheaper to build and would have above average performance. What's the downside?
How you like to be told, when you get your oil changed at 50k, that your engine is leaking out of just about every gasket? I have yet to really see a Honda or Toyota, 4 or 6, have the abundance of problems that GM has with their V6s and 4spd autos leaking.
My beef wasn't with the new design, which just from the numbers and driving the two different engines, 3.4, 3.8 vs 3.5/3.9, tells me that there was a huge improvement for smoothness and power output. My problem is that they went and redesigned these new engines and they failed to fix the leaking gaskets that plagued the old GM V6s in the first place.
I've not heard anything about 3.4s having excessive oil leaks from other areas, if that is what you mean. But even if they did, it is quite possible that they have changed to different materials or designs of the gaskets where leaking was a problem...
How do you know they haven't come up with newer gasket designs and/or materials, even though the head/block/intake interface is still similar to the design of the old 3.4 (referring to the common intake manifold coolant leak that the 3.4L had)?
Lets make something clear, I think the new 3.5/3.9 are a big step forward in smoothness and power over the old GM v6s. My beef is that they did not fix the one thing that probably turned more people off of GM v6s than anything else, oil leaks. I know that the new Toyota 2.4 and older 1.5/1.6 Honda 4s have oil pans that do end up leaking, but all the Hondas I've seen all have over 100k on them and the Toyotas are actually quite easy to fix, from a labor stand point. Even the old Toyota 2.2s have problems with cam covers leaking, though it again is not a problem until over 100k. This is what I see at work, day in and day out, changing oil on cars for a living. In a college town you see a lot of small cars covering a lot of years.
Like I've said, I'm glad that GM is going to start only using the 3.6 and hopefully the 6spd auto will replace all the 4spds. I can only hope that GM has used better materials when it comes to gaskets this time around. I have reason to hope since all the Ecotec engines I have seen have not had a single problem with them when it comes to leaks. This is what a lot of people will call reliability problems when they are questioned about it.
CARiD
Jan 27, 2015 06:27 AM
CARiD
Dec 26, 2014 04:20 AM
VetteThreat
Jul 18, 2002 07:40 AM
