EPA sets rules for non-road motors to add cats
This probably should have been done years ago. There should also be some options to grandfather in some boats and machines if the upgrade costs more than the boat/machine is valued at.
Personal watercraft should also be moving to a more ecofriendly fuel than gasoline/oil. There is almost no way not to spill or mix fuels with the water.
the 2 stroke is pretty much dead in the boating world.
Yamaha has been using catcons (which is a catalytic converter) in there 1200/1300 2 stroke jet skis for a while. the problem with them is they take a huge beating from the jet ski bouncing around and break down turn into a ball of crap and burn the motor up so most people remove them.
EDIT: at least on multiple blade decks, there is a lot of noise from gearbox assemblies, belts, etc, depending on if the deck is an interference deck or not. belts are quite a bit quieter than gearboxes though.
Having said that, the thin-walled aluminum cast blocks that make up most lawn mowers radiate lots of noise, so a quasi-muffler-cat isn't going to kill all the sound.
I recall that Cali has stated that nearly 40% of emissions in the state are from off-road sources. Seems overdue. Cars are clean enough- we need to let catalytic tech advance while holding emissions limits, to allow lean-burn for economy, for instance.
This is a great idea for lawnmowers.
1) I don't like smelling like no cat gas after mowing the lawn.
2) Quieter. Why hasn't lawn mower technology gotten any quieter in the last 50 years? A new dishwasher has a spinning blade but makes as much noise as a coffee maker. Yet a lawnmower sounds like a construction site.
3) As it is now, I can drive my car for 6 hours and pollute less than 1 hour of mowing the lawn. Something seems wrong when you have 300HP pushing 3500 lbs of vehicle for 6 hours yet a 5HP non self propelled 40 lb lawnmower spews out more pollution in a single hour.
If only I could hook a lawnmower blade to the bottom of my car, I'd be laughing.
As for boats. I don't know if new engines are any better than when I used to go boating 15 years ago. But back then it was nasty. Outboard engines just reeked of fuel.
My wife wears hearing protection when she's on the tractor (as you can tell, she's smarter than I am), and sticking all the mufflers you want on the engine wouldn't change that.
BTW, that Kubota was already compliant with EPA and CARB rules for sub-25 HP engines (even though it makes 32 HP), so you can run that thing all day long without smelling like diesel. It might puff smoke for a second or two when it's sub-freezing, but I let the thing warm up in the barn while shoveling snow away from the door and it doesn't create any obnoxious fumes.
If you can figure out how to quiet down lawn equipment, you won't get Joe Six-Pack to buy it because he'd still rather spend $200 on a POS MTD than $500 on a Lawn Boy or Honda that'll last half his lifetime, but professional greenskeeper might very well be interested. It seems that the folks who pay big bucks to live alongside a golf course would prefer that the effort required to maintain that golfcourse be neither seen nor heard. The first is covered by a schedule that starts at 5AM, which then creates a bit of a problem for the second demand.
I don't think so. You can easily figure that out by playing with an electric mower.
And when we have to meet decibel standards on our equipment, it is always the decks/blades that are tweaked to try and make quieter. Unfortunately there's only so far you can go in terms of modifications before it starts effecting the cut of the deck.
A buddy of mine has an air compressor in his work van that's powered by a 5.5 HP Briggs & Straton engine. You can easily talk over it while it's running - and it's basically inside of a big metal box. I'm going to have to agree that it's not the engine that's the problem.
So how come both my largest size available Vornado fan as well as radiator fans can spin fast but quiet, but a lawnmower for some reason has to be loud?
I wonder if I wrapped my lawnmower in sound deadener, it if would make a difference? I doubt it. Seems like the engine is the overriding noise maker.
I'll probably mow the yard today.
