CTS-V LS2 Automatic
Re: CTS-V LS2 Automatic
Originally Posted by grossesexy
Where is the middle finger smiley? Pretentious ***** much? Try finding a used z28 with a manual that isn't absolutely trashed. Maybe you should think a little bit before making a statement like that.
This coming from an M6 owner.
I dunno.. I really like manual..
Never even sat in a Ferrari. but all those reviewers, that toss them around the track seem to like their paddle shifters.. You toggle the paddle and you get a perfect up or down shift every time, faster than a human can do it with a conventional manual shifter... although the suspension reacting to the shifts is kinda insane too.. Your shifts are faster, and you hvae less to worry about, so you can concentrate more on actually driving through turns, which should make your lap times faster....... Sounds intresting in my book..
Originally Posted by BigggD222
Which also means it takes less skill to be able to drive a car such as a Ferrari around a race track.
Or you can argue someone with equal skill can be even faster with a paddle shifter than they would be in a comparable car with conventional stick
Or simply, if you are in a Ferrari, the expectation bar is raised.. and it would be sure embarassing if you get you get beat by, say, someone in a Z06..
Originally Posted by greg_nate
According to the Vette sites, the new A6 trannys are tough as nails. The 6l80e is smaller and lighter than the 4l80e. It is also stronger with a much higher torque rating. Apparently, they're built by Borg Warner, which is about as good as it gets. Their clutch-on-clutch technology is supposedly top of the line and the programming ability of these trannys is untouchable. Everyone, including myself, is eagerly awaiting retrofit kits for our vehicles.
B-W might be a supplier for components in the transmission (I have no idea), but they are not building the transmission and selling it (like they have done with the T56 manual, for example). GM is building the 6L80E.
WobblySausage
Oct 7, 2015 10:09 AM
