C6 brakes...what a joke....
Old Jan 19, 2006 | 12:27 PM
  #61
trackbird's Avatar
Re: C6 brakes...what a joke....
Originally Posted by Doug Harden
Lose the attitude...no need for that here........
No attitude, I'm not really planning on coming back to this thread and it saved me a lot of typing trying to explain it nicely.
Brakes cool from the inside out. The rotor naturally "throws" air out from the center (and is backed up by the information you posted). Trying to use the veins backwards to pull air in, against the natual energy that is pushing it out is not a good idea, and doesn't work very well. Brake ducts are effective, but it's because they concentrate cool air into the center of the rotor and it is naturally distributed by the rotation and the veins of that rotor. None of this is really up for debate. So, when Aaron91RS started referring to people as "ricers" because they wanted brakes that were designed and built properly, it became obvious that he missed the point. The point is that they took the time to build 6 piston calipers (usually considered an upgrade) and put them on a $70,000 sports car and didn't bother to optimize the package at the additional cost of $100 or less to the manufacturer. Many people look to GM parts for inexpensive upgrades to existing cars (like you, putting C6 stuff on your C5), but when it's not really an upgrade, or not as much of an upgrade as it could/should be, due to the manufacturer taking an unacceptable shortcut, it's frustrating. Chris posted this because it seems dumb for GM to save $100 (or very likely $100-ish) on a $70,000 car and seriously flaw the performance of the brakes in the process. It's probably not an issue for 99% of the guys who buy these cars, but for that last 1 or even 10%, it's a very big frustration to spend good money to "fix" a brand new car to make it perform as it should have from the factory.
You either understand this, or you don't. He obviously didn't. He has his opinions (that we who are concerned are ricers) and I have my opinion (that he's an idiot). We can agree to disagree, or we're going to have to this time.
I'll report myself to the admin now.
Have a wonderful day!
Old Jan 19, 2006 | 12:35 PM
  #62
Chris 96 WS6's Avatar
Best Post EVARRR!!!1111!!!1!
Old Jan 19, 2006 | 12:41 PM
  #63
RussStang's Avatar
Old Jan 19, 2006 | 02:27 PM
  #64
WOT's Avatar
WOT
Yeah TB you're a big stupid, meanie head!!! You suck!!!
It's odd how the armchair experts in this thread are calling people internet engineers when all they are doing is speculating themselves (i.e.; Aaron91RS).
The brakes are seriously flawed bottom line. And whomever designed them is a dumb@ss. Ok, ok the beancounter that placed the constraints that caused this. Opps did I post that in the GM leghumping section of CZ28.com? That reminds me why I don't post here anymore.
I'm done here. bye
Old Jan 19, 2006 | 03:01 PM
  #65
anasazi's Avatar
But there again, this was in hardcore race conditions...not everyday spirited street driving.
i know its been said before, but there is no need for dry sump oil systems on street cars either
its just very odd that a $70,000 "supercar" that is supose to be pretty damn close to a race car off the lot would have been cheaped out on the rotors. GM really shouldn't have done it simply because its what it is, a high profile, expensive sports car.
Old Jan 19, 2006 | 03:22 PM
  #66
Doug Harden's Avatar
Prominent Member
Guys, I don't disagree...but even $1 per car is huge as for as the beancounters go.....but I do agree that it should not have been saved here...on this car.
I also don't know why Ford & MB did the exact same thing, so don't just crucify Chevy over it.
Why is it that AX & RR guys are so self-righteous though? I've met more people like this in this part of the hobby than any other....
Old Jan 19, 2006 | 03:35 PM
  #67
Aaron91RS's Avatar
Funny I am an idiot and yet no one has posted independant scientific tests showing it doesn't work.
I'm sure Ford, Chevy and MB all 3 overlooked the same thing
Old Jan 19, 2006 | 04:00 PM
  #68
trackbird's Avatar
If everyone else jumped off of a bridge.....
GM put the correct veins in the rotors on the C5 and even the lowly C4's (with the HD package at least). GM has always done it right....until now.
I swore I wasn't coming back here, but I was referred back by someone.
From Brembo's FAQ's (because Brembo wouldn't know anything about brakes).
http://www.buybrakes.com/brembo/faq.html#q28
Which direction should the discs rotate?
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
Straight
Pillar vane (comprised of many small posts)
Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Please see figure. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
BACK TO TOP
http://tetra.mech.ubc.ca/CFD03/papers/paper30PD1.pdf
The airfoil shaped veins cooled the best, but they do not specifically note the direction of rotation.
Most of them are frustrated with being asked the same questions over and over that a basic search would usually turn up the answers to and then getting argued with about stuff that's widely available knowledge.
Oddly, the same road race/autocross guys are the best guys ever to meet at the track. Every single one of them will help the competition (unlike most of the drag racers I know, who seem to form a clique and talk to nobody but their friends. Maybe it's because there is money involved....).
It appears that GM, Mercedes, etc have decided that (assuming that the other cars have the veins running backwards and not just the drilled holes) they could save a few bucks and risk someone noticing that they cut corners. Again, as we already stated, for street use, it's probably not an issue for most people. But, for a performance car (and a 500 hp one at that) that they took the time to build roughly 14" diameter brakes, hang 6 piston calipers on and then not finish the job properly is just not acceptable. If they felt that it needed 6 piston brakes with 14" rotors, why didn't they feel the need to cool them properly?
Of course, they also know that cross drilled rotors are just there to be pretty, so maybe they designed the whole system with "curb appeal" in mind and didn't intend for it to work well at all.
Funny I am an idiot....
I'll stand by my original statement.
Old Jan 19, 2006 | 04:08 PM
  #69
I find it strange you are arguing that there's no negative effect of the rotor trying to pump air in opposite of all the centrifugal force caused by the rotation at, oh, 100+mph.
I think Trackbird's example is sufficient info. Its RICE not to put the correct parts on the car.
Bling cross drilled rotors are hardly better than fake plastic intercoolers.
Old Jan 19, 2006 | 04:39 PM
  #70
Prominent Member
There's some better info here...starting around post #6....
http://www.z06vette.com/forums/showthread.php?t=92672
Pay particular attention to post #19.....Jeff Ritter from StopTech...
Old Jan 19, 2006 | 04:40 PM
  #71
JakeRobb's Avatar
Super Moderator
Okay, I read the first 20 posts or so and got tired of checking to see if someone clarified this. Sorry if I'm reposting something that's already been said:
If the slots are going backwards, that does NOT mean it's going to add extra heat to the rotor. It's just not going to cool as efficiently.
Regardless of your brake setup, braking is going to cause the rotors to increase in temperature. Good cooling characteristics will slow the increase, and reduce the time the rotor takes to cool again afterwards.
Backwards slotted rotors have better cooling characteristics than rotors with no slots at all (all other things being equal).
Old Jan 19, 2006 | 05:43 PM
  #72
anasazi's Avatar
quoted for the lazy:
Originally Posted by J Ritt
Under the heat stress placed on rotors at the track, drilled rotors WILL crack more easily than slotted ones, period, end of story. Drilled rotors are a marketer’s dream. Porsche sent the world down this path by introducing drilled rotors on the 911, and it remains that way today. People want their brakes to look like a 911’s. We always ask if our customers plan to track their car. If they do, we universally recommend slotted over drilled. Directional rotors make a huge difference depending on their proper orientation, and vane design is absolutely one of the most critical determinants of rotor performance. Metallurgy is extremely important as well.
Old Jan 19, 2006 | 07:10 PM
  #73
Prominent Member
Also quoted from Post #19....
So, it’s tough to fault GM on their pad choice to ship the car. I think it was actually a good choice, and the brakes will work great on the street, autoX, canyon driving, etc. Most people who drive the car under these conditions won’t run into any problems. Here’s what probably should have happened though…They should have had Ferodo make the DS3000 in this pad shape as well (or any other pad manufacturer make their top of the line, full-out race pad in that shape…i.e. PFC ’03, Pagid RS-14, Hawk DTC-70, etc). GM could have sold them at launch as an official GM performance upgrade part. The only problem is, now they are condoning, if not encouraging taking the car on the racetrack…which raises warranty issues, etc. The fact that the car was marketed as track-capable is a fine line. How do you define ‘track capable,’ what type of track are we talking about, how long are the sessions…the list of ambiguity goes on and on, and there are valid arguments on both sides of the coin. As an aftermarket manufacturer, I can tell you that this is a VERY sticky area. You want your product perceived as race-ready, but you can’t account for all of the stupid things people will do with your product, and how they will hurt or kill themselves in the process. For example, here’s one of our solutions…when we ship our big brake kits out the door, we put a neon pink sticker on the pad box that ships with the kit that reads, “for street use only…do not use these pads on a racetrack.” Well guess what, we still get 1 call a week with customers complaining about pedal vibrations. Our first question is, “did you use the pads we sent with the kit on the racetrack?” Yes is the answer more times than not. Well then, of course you have a vibration, as you’ve taken the pad outside its temperature range and gotten an uneven deposit on your rotor!
The whole scenario is extremely complicated, and the issues that arise are endless. So, just keep these things in mind before you completely crucify the guys that built / designed this beautiful machine. As a much smaller company, we have a hard enough time dealing with these issues. Fighting these battles within a giant organization in which there are many differing goals and agendas must be terribly stressful for the technical team. I can assure you that their feedback and what the marketers heard them say is not the same thing. All I’m saying is think about pointing your displeasure in the appropriate direction before you call out David Hill and pants him at the next national vette meet. I can assure that the engineers on the team wanted more power, more carbon fiber, better handling, and couldn’t give a rat’s *** if the brake pads squeaked a bit on the street, or if the idle was a tiny bit lumpy as a tradeoff.
Old Jan 19, 2006 | 09:40 PM
  #74
RussStang's Avatar
Sounds like apparently someone overlooked it, for whatever reason. Your arguement is going to sh*t, by the way. What could you have expected by calling people ricers for caring about the way the hardware on an expensive sportcar is supposed to work?
Old Jan 20, 2006 | 07:54 AM
  #75
What's the difference? Net effect in the end is increased rotor temp on one side of the car vs. the other.
Duh!
Yes, and a properly cooled but smaller rotor will actually stop better than a bigger, poorly cooled rotor. So GM chose big, poorly cooled brakes when they could have saved just as money by doing the proper rotors and less diameter and less caliper.
There's a difference between SLOTS and cooling vanes inside the rotor. We aren't talking about the dumb slots, as the Z06 rotors aren't slotted anyway, we're talking about the internal cooling veins between the two rotor surfaces. There's not been a domestic car built I can remember that had solid front disks, so yes obviously vented discs cool better than non vented, but its the same principle as above....a properly cooled rotor will have as good or better stopping power as a bigger rotor that is not properly cooled.
Even if this was $50 per car, they're going to sell maybe 5000 of these cars a year, so they have saved $250,000.....pennies compared to what these guys drop on countless other non-product related luxuries.
