Is this the best that GM can do?
Old May 22, 2003 | 09:07 PM
  #16
Z284ever's Avatar
Originally posted by guionM
Would there be any disapointment?
Nope.
Old May 23, 2003 | 07:06 AM
  #17
Eric Bryant's Avatar
Nope, I could deal with it. I want a flat and wide powerband, good fuel economy, good drivability, and low maintenence cost/effort - seems like the blown 3800 gives me all of that.
I'd love to see this engine in front of a stronger tranmission and driving the correct set of wheels. It'd be a worthy successor to the old turbo Regals, IMO.
Old May 25, 2003 | 01:25 AM
  #18
fyrhwk1's Avatar
Originally posted by R377
I knew I'd get a reply like this.
I don't really want to sit here and debate the merits of OHV vs. OHC because they each have their attributes and their place in the market. There's two main problems with OHV: 1) they're perceived as being yester-tech; and 2) despite their good numbers, there's no way you can compare the refinement of the two architectures (think Cav's 2.2 OHV vs. Ecotec; 3800 vs Honda V6; LS1 vs. Northstar). In a time where pretty much every new car will go 200,000 miles and start on the first twist of the key, consumers are placing more emphasis on their wants instead of their needs, and not many people want to drive an engine that reminds them of a Massey-Ferguson.
Not that I disagree with you on the OHV area, but owning a 94 bonneville (3800 series I) and my mother having owned a 94 accord V6, the bonneville rode quieter and smoother with less problems then the accord ever did. Unfortunatly I can't compare the both as the accord was sold, but for the 2 years we had it I honestly can't say I heard any less engine noise from it, nor did it feel like it moved the car around any faster, although it did run through it's rev range quicker.
Come again? High compression is virtually almost always more efficient than low compression. This is the primarly reason that diesels have better fuel economy. The reason that we're not all running around with 14:1 compression is fuel quality, and emissions (higher combustion temps = more NOx emissions, also a characteristic of diesels).
I don't suppose anyone has the dynamic comp ratios of both the 3800 NA and SC motor? Those would play the largest part in this argument. Plus under partial throttle (maintaining speed on the highway) the less air you have going in there the less fuel needed, the higher dynamic compression engine at this area, likely the NA motor, will have an advantage i'm sure,, but how much? I wonder if it's anything noticable.
Old May 25, 2003 | 07:38 AM
  #19
R377's Avatar
IIRC, the 3800 SC uses a version of the Miller cycle where the intake valve stays open partway through the compression stroke to reduce cylinder filling. That would mean the effective compression ratio is less than the n/a engine while maintaining the same expansion ratio (important for power and efficiency).
Old May 25, 2003 | 08:30 PM
  #20
fyrhwk1's Avatar
Are you sure? not that i'm saying you're wrong, but I can't picture them purposely allowing fuel to blow back out of the intake valve, plus with the blower the engine would be working against itself, wouldn't simply holding the exhaust valve open longer do the same result? although they'd probably have issues with emissions if they do that...
Old May 26, 2003 | 01:26 AM
  #21
Ken S's Avatar
I read whats limiting the power is the transaxle.. For some reason they didn't want to use the stronger ones from Cadillac..
Anyways, these cars are more or less placeholders till the next models...
Personally, depenidng on the economy and how things pan out, I can see myself, $-wise, buying a new car around 2005-2007.. Hopefully by then I won't be saying "Is this the best that GM can do?"
Old May 26, 2003 | 05:37 AM
  #22
R377's Avatar
No, I'm not 100% sure since I've never seen the cam spec. True, the blower is working against the rising piston, but the effect is marginal.
The idea of holding the intake valve open longer is to reduce cylinder filling and therefore effectively reduce the compression ratio. But since the rest of the valve timing is the same, the expansion ratio is still the same, and that's what's important to power and efficiency.
The Miller cylce has been used on other s/c engines such as the Mazda Milenia.
