4 second delay for full power?
Ok. So just to make sure I have this clear, I can take my 2006 M6 GTO that makes ~340 peak RWHP stock, get it tuned with your software, and walk away with ~390 peak RWHP stock. Correct?
No comment.
Thanks.
Bob
I didn't think I needed to qualify my comments?
Thanks.
Bob
Do they have actual hard proof on this?
If so, why have to settings then? Does it cause harm to always put the truck in tow/haul mode?
I've always wondered about that in my Av...
I know what I'm talking about and I'm not talking about rwhp. That's 50 fwhp!
provided you use PULP.Thanks for your interest. I do tune my own vehicle.
that sucks, first stop after i drove my truck off the lot would be to get it tuned
one thing i also noticed was the crappy approach angle the silverado has... its nearly half as bad as the other two trucks, i would hope the z71 was better but i think the base 4x4 model should be way better than it is.
But anyway, so lets play this game....50 flywheel HP - given a typical 15% power loss - should equal ~42 RWHP. Correct?
So let me rephrase/correct my question/statement: You're saying that through tuning alone (via a chip, reflash, etc), you can pick up ~42 RWHP in an otherwise bone stock LS2?
Thanks.
Bob
PS....Premium (PULP) is recommended for LS2s (Stateside), so that's not an issue.
I don't.
Thanks.
Bob
Thanks.
Bob
http://motormouth.com.au/myresources/fueltypes.aspx
I wouldn't use your 15% loss calculation, I'd use 25-30% driveline loss... I would say around 30rwhp would be the go.
Have a read here... http://www.chipmaster.com.au/monaro.html.
1 kW = 1.34 hp
Sorry to digress people... but Mr Bob Cosby is a non believer and is quite persistent.
If you're still a non-believer Bob, I can't help you.... but lots of LS1/LS2s here get a 40 rwkw (=55rwhp) gain from MCAI, 2.5" exhaust, and flash edit for PULP.
1 kW = 1.34 hp
anyway, premium unleaded in Australia is higher than what it is over here.
Have a look here.
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-95 (regular) in Europe.
http://en.wikipedia.org/wiki/Octane_rating
Additionally, here's an article you wrote on the this very subject: http://www.ls1-australia.com/forum/viewtopic.php?t=91. Why no mention of "25-30%" in that article? BTW, I know Lee Bender and Paul Svinicki, and happen to agree with their conclusion.
Further, given a 400 HP rating, and using a 25% loss, that would yield RWHP numbers of 300 for an M6 GTO. Is that the real world case?
It is interesting though that we have gone from "50 hp" to "30 RWHP". That's a 40% loss, in case you didn't know.
So color me a non-believer....with data to back it up.
Perhaps "down under" the factory calibration is WAY conservative and that is the difference.
There....you have an "out" now.
Bob
PS...agree totally on the octane ratings.
Back on topic, the performance of the 6.0 was a bit disappointing. The Silverado beat the Tundra in every other aspect in the review. I would have thought the 6.0 would give the Silverado enough to basically negate the advantage of the new 5.7 in the Tundra.
Think of it as skip shift in our cars. It is probably done for emissions/fuel economy reasons.
No, that is relavent to the current topic.
Some say that the faults of power delivery of the 6.0 tested would have been solved by putting in tow/haul mode.Thats why I'm wondering, does it really make that much of a difference? Does it really add more stress to the drivetrain then if I flip this mode on all the time (hauling or not), on the older trucks and on the newer gmt-900 trucks?
I can imagine accel and hauling times would be imporved with a 6 speed in the Gm trucks. There's times where I think an extra gear in between would be perfect in my Av's 4 speed. Not to mention tq management between shifts softening everything up.
Auto 2wd LS2 TB SS's with PCM re-calibration only can see as much as ~35rwhp gains.
I think THAT is quite significant, and I don't think they have the 4 second delay as mentioned in this thread.
With that being said, I think getting a ~40rwhp gain from the Silverado, at SOME POINT along the graph, is possible.
Mike
Really? I have real live data that shows an engine make ~390 HP on a engine dyno, and ~345 RWHP on a dynojet Chassis dyno (SAE). No changes to the motor. T5 tranny. Do the math.
Cool. They use 30% (or at least did in that article). And? Why didn't you use them in your article if that is what you believe? Once again, I point to realworld examples of LS2 dynos - you just don't see 300 RWHP LS2 GTO and your article above.
We can agree on this. I think you're full of bull trying to convince people that you can pick up 50, 42, or even 30 RWHP on the average bone stock LS2 with just a dyno tune. Been around EFI and dynos too long.
Well gee wally, I don't think we were talking about other mods, now were we? I'm quite aware of what "bolt-ons" will do with an LSx series engine.
Bob
Bob
For starters, I didn't write any article but posted it for reference on my site from a Freud forum. It's up to individuals to agree or disagree with the article I linked (not wrote).
And where exactly did i mention bone stock in my post? I didn't. You did? I said 50 hp and I stand by it. You mistook it for 50rwhp. It's your problem for not reading posts properly, Mr!
Another problem with your reading I want to point out... nowhere did I mention LS2... only 6.0L. I'm surprised you haven't heard of L76 and L98?
I guess you're having a bad day... and trying to pick a bone with someone. Well, not interested Mr!
As I said, you don't believe me or the article I linked, it's your problem, not mine. I can't help you.
Have a nice day!
Hi Bob,
Mike
Mike
"Mate", I have no reason to be anything except calm.
Ok - so I'll ask you - do you agree or disagree with the "reference" article I linked from your page?
Surely that's what you meant, and I just misunderstood.
What's the difference?
But lets go to the LS2 for a sec....given that it is a 6.0L....what can you pull out of a 6.0L LS2 with just a PCM tune?
I had never heard of L76's and L98's that seem to pertain to Aussie cars. Now I have.
So I guess these are the motors that you gain 50 HP with using just a tune?
And for not being interested, you sure replied a lot.
I don't believe your 50 hp gains though. Sorry.
Have a nice day!
Bob
