3.8 V6's replacement
GM plans 3.9-liter V-6
By Richard Truett
Automotive News / April 11, 2003
General Motors will add a pushrod 3.9-liter V-6 engine to its lineup in the 2006 model year, the automaker said on Friday. The engine will be built at the automaker's Tonawanda, N.Y., engine plant.
The new V-6 and a 3.5-liter version using the same architecture will be equipped with GM's fuel-saving cylinder-deactivation technology that shuts down cylinders based on vehicle speed and engine load. GM says the system delivers an 8 percent gain in fuel economy.
GM is investing $300 million in the plant for new machinery and production lines. The upgrades are expected to be completed by the fourth quarter of 2004. The Tonawanda plant produces GM's 2.2-liter Ecotech four-cylinder; 3.1- and 3.4-liter V-6s; 8.1-liter V-8; 2.8-liter four-cylinder; and 3.5-liter five-cylinder engines. Employment is 3,340.
By Richard Truett
That 3.9L sounds like good news. I think this would be the new base Camaro engine.
We can assume that do to cost, the base V6 Camaro will not get a DOHC V6. So it will mose likly stick with a pushrod V6
The 3.5L pushrod V6 puts out 200HP so a good guess would be that the 3.9L version of this engine will have about 225HP / 240tq give or take a little. This would make a competitive base engine.
Plus the timing is just about perfect.
Originally posted by Sixer-Bird
Is this 3.9L still going to be a 90 degree V or is it a 60 degree? Is this based of the 3.8 or is it a completely new design?
The 60* V6 has had a long run. Didn't it get its start with the X-car? Kinda surprising that GM's going with the 60*, but I guess it makes sense when it comes to development/packaging costs.
Originally posted by stars1010
I honestly dont know a lot about this motor. But mine has 116,000 on the clock and still runs great. Seems liek a good design to me!
Re: 3.8 V6's replacement
Originally posted by guionM
[B]
[B]
Sure Mercedes has been playing around with cylinder deactivation on the S-class for the last few years, but mostly on European models. I'm not saying that GM's move in this direction will be another disaster, but I would venture that anyone with an ounce of common sense will avoid these new V6s for the first few years.
It makes me wonder how many buyers have been complaining about the fuel economy of the old Buick V6. When a car like a Buick Regal or a Chevrolet Impala can pull 35mpg in real-world highway driving, that's pretty impressive
Re: Re: 3.8 V6's replacement
Originally posted by redzed
Here's a stupid idea, at least for anyone who remembers the Cadillac 4-6-8. The 1982 cylinder deactivation concept failed in part because of the lack of technology, but it really wasn't the brightest way to fuel efficiency. Ever hear a V8 firing on four cylinders - not too smooth! Wait until you hear a V6 cruising on just three.
I've heard that the 60*(3.4) actually sounds better than the 90* (3.8), because of teh flow
Re: Re: Re: 3.8 V6's replacement
Originally posted by Z28Wilson
WHY does everyone keep referencing the failed 8-6-4 Cadillac motors of 2 decades ago? This is NOT the same technology, do you really think GM would go down this road AGAIN if it hasn't been proven through extensive testing to work?
Cylinder deactivation is an uneccessary technology. Worse yet, it leaves you with unresolved primary inertial forces in otherwise sound motors. Even if you remove the compression in deactivated cylinders, you hardly have a balanced engine.
Re: Re: Re: Re: 3.8 V6's replacement
FWIW, GM's DOD closes off the valves, leaving air in the cylinder (acts like a spring).
Assuming it works and is reliable (I don't see why not, with all the variable valve timing etc. these days) I think it is a valid technology. I don't think it makes sense to reference cars from 20 years ago, either. Why would you not want it? Wouldn't you like to burn less fuel and pollute less - with no loss of performance?? At minimal cost???
