2010 Chevrolet Equinox: SUV shines among rivals
Old Jul 19, 2009 | 11:00 AM
95redLT1's Avatar
http://www.wheels.ca/article/asset/764593
GRAND BEND–The compact SUV segment accounts for about 27 per cent of the truck market in Canada, and about 12 per cent overall.
It's one of the few niches that remains strong in the troubled car business, as consumers like the utility these vehicles offer, and the lower fuel consumption compared to their intermediate or full-size siblings.
The Ford Escape and Toyota RAV4 have been the biggest players to date, with Honda's CR-V normally taking third spot.
As usual, General Motors' multi-brand strategy works against it for bragging rights – combined sales of the Chevrolet Equinox and the similar Pontiac Torrent would put GM close to third place.
That problem partially goes away with the 2010 Chevrolet Equinox, because the Torrent, like all Pontiacs, is dead meat after this year. But GMC will add the Terrain.
As before, the Equinox – which is in showrooms now – was largely engineered in Canada and built exclusively in the Ingersoll plant GM shares with Suzuki.
GM actually started surveying prospects for the new Equinox shortly after the original came out in 2004. The top reasons buyers purchased them: fuel economy, value, quality, style and safety, which also implies four-wheel drive.
The new Equinox should do well, if for no other reason than it really scores on fuel economy.
The basis for Equinox remains the platform also used for Saturn Vue and Suzuki XL7. The wheelbase remains 2,857 mm, although the handsome new body is a shade shorter and a tad wider.
A key feature in the bodywork is that the rocker panels are actually part of the doors, so when you get in or out, you're less likely to get your pants or dress dirty – especially critical in a taller vehicle like this.
Another highlight is fit and finish are excellent, and the detailing leaves a quality impression.
The base 2.4 L four-cylinder engine produces almost the same horsepower as (although substantially less torque than) the 3.4 L V6, which was the sole engine in the previous generation Equinox.
it offers best-in-segment highway fuel economy, its combined city/highway Transport Canada number is the best non-hybrid (i.e., Ford Escape Hybrid) in the segment, and is in fact better than any 2.4 L four anywhere, including those of the Toyota Camry or Honda Accord.
Two main contributors here are direct fuel injection, the first time GM has used this technology in a non-turbocharged four-cylinder, and the six-speed automatic transmission, which is standard across the board – more gear ratios mean the engine can stay at or near its sweet spot more of the time.
Other more subtle fuel economy-enhancing measures include the ECO button; push it and, among other things, the transmission shifts at lower r.p.m., the torque converter locks up earlier, and fuel is shut off in deceleration. Why aren't these things done all the time? Mainly because there are drawbacks in driveability, refinement and noise. The ECO button gives drivers the option to choose.
To help compensate for the noise, GM has introduced active noise cancellation, just like some stereo headphones. Microphones over the front and rear seats pick up unwanted and irritating booming noises, and cause the car's audio system to generate sound waves of similar frequency and amplitude, but in opposite phase – cancelling each other out.
The lineup continues to offer a V6, a new 3.0 L design, related to the direct-injection 3.6 L used in the bigger Chevy Traverse and its clones.
Tim Herrick, vehicle chief engineer for Equinox, said Chev was going to offer an ECO mode for this engine, too, but found that the smoother-running V6 did not exhibit the driveability issues when these techniques were employed, so they effectively made ECO standard – there is no button to push.
The value story starts with pricing. The base trim level front-drive four-cylinder Equinox starts at $25,995, but the expected volume seller 1LT trim is $27,725, which is within a few hundred dollars of the major competitors.
However, the four-wheel-drive upgrade is just $1,610 in the Equinox, versus two grand or more in the others.
Equinox also features standard stuff like directional stability control and traction control.
And the dreaded remote start is also standard. If your dealer can't rip this nonsense out by its roots, for the sake of your engine and the environment, please resolve never to use it.
Among optional features rare to unheard-of in this class are power tailgate, dual rear-seat DVD system, Bluetooth connectivity for cellphones, 40 gig hard drive and USB port for your audio entertainment, heated leather seats, SatNav and backup camera.
I split the drive from Toronto to this Lake Huron resort town between a brace of Equinoxes, both top-of-the-line LTZ trim level four-wheel drives, the first with the six, the second with the four.
Frankly, unless you're planning on doing some semi-serious towing, (the V6 is rated to haul 1,590 kg, the four only 680 kg), there's little point in spending the extra $1,795 the V6 costs.
Neither engine is exactly a ball of fire in full-on acceleration, and despite the efforts, they both can be a bit noisy at times. The V6 is faster against a stopwatch than the four, about a second quicker from rest to 100 km/h.
Ride is on the firm side, but the handling is fine for the intended purpose.
There was a fair whack of tire noise on certain stretches of pavement; I'd have to drive it over known roads to determine if this was down to the car or the road.
The brakes need a fair heft to scrub off the speed; I'm betting that those of smaller stature will want a lighter effort.
The autobox has a manual mode, which operates a bit oddly. Pull the lever back to M, and, depending on how fast you're going, the transmission automatically downshifts, in my case usually from sixth to fourth. Not sure why it does this.
Flicking a switch on the side of the gear shift lever puts you in any ratio the tranny can reach without grenading the engine.
Here's the odd part: if you're in sixth-gear manual mode, the instrument panel posts M6. If you mash the gas pedal, it will downshift one, two or even three gears – so much for it being a "manual" mode. But the dash display remains M6! In other words, it doesn't tell you what ratio the transmission is in, like virtually every other manumatic does, but rather the ratio you have selected.
The front seats are roomy, comfortable, and supportive. Rear seat legroom is enormous, especially when it is cranked full-back, and the flat floor means three abreast back there will not be too hard on the middle-man's feet.
The rear seatback split-folds – not completely flat, but close enough to be useful.
My two test vehicles were well built, although the four-cylinder had a buzz in the instrument panel, and a few plastic bits, notably, the storage cubby at the base of the centre stack, look a shade economical,
My co-driver also complained about reflections in the instrument panel see-through panel, which he found distracting.
General Motors provided a couple of examples of the Toyota RAV4 and Honda CR-V for back-to-back comparison. Give them credit; they tried hard to equip the vehicles to a similar level – they were all four-cylinder versions.
I tried the RAV4 first. When I started it up, I wondered if it was a diesel because the engine is very noisy, especially at idle. This is where Equinox's sound-cancellation system shines.
The RAV4's interior was also very plain, and not as well-finished as that of the Equinox. Road noise was more pronounced, especially over a series of rumble strips during our test-drive route.
The Honda was nicer inside than the Toyota, although not to the luxury level of Equinox.
Neither of the Japanese-branded cars came close to Equinox in power output or fuel consumption, neither offers a six-speed transmission, nor – standard sunroofs apart – anywhere near the equipment level of Equinox.
The Escape starting price is a few hundred less than the cheapest Equinox, but offers less equipment, less power, and uses more fuel.
The challenge for Equinox will be getting on the shopping lists of CR-V and RAV4 intenders.
My own sister-in-law, a multi-time Honda owner, recently traded her old CR-V in on a RAV4, mainly because her big ol' yaller dog Tanner fits better in the Toy.
Would she have even considered a Chevrolet if it had been on sale when she made that purchase?
Probably not.
Now that Equinox is on sale and if she were making that purchase today, I would strongly recommend she take a close look.
Old Jul 19, 2009 | 12:52 PM
97z28/m6's Avatar
the 3.6HF was also available...
Old Jul 19, 2009 | 01:43 PM
Derek M's Avatar
Probably not.
Hope she gets the same consideration, none, when consumers are in the market to procure whatever it is she does for a living.
Something is certainly wrong when one doesn't at least consider something that's made right in your back yard.
Old Jul 19, 2009 | 01:50 PM
MustangEater82's Avatar
Am I reading it right that it claims
31mpg city, 46 mpg highway in the 4 banger?
23mpg city, 31 mpg highway in the v6?
FUEL CONSUMPTION: (I4) City 9.2 L/100 km (31 mpg), hwy. 6.1 L (46 mpg); (V6) City 12.1 L (23 mpg), hwy. 8.0 L (35 mpg)
Old Jul 19, 2009 | 02:00 PM
R377's Avatar
We use Imperial gallons in Canada, which are about 20% larger than US gallons.
Old Jul 19, 2009 | 02:52 PM
Threxx's Avatar
Your fuel economy rating standards must also be more forgiving because the Equinox 4-cyl is rated at 32mpg highway in the US.
Still... that's pretty incredible. My Aura with a 6-speed auto like in the equinox and the same 2.4L ecotec sans direct injection only has a highway rating of 33mpg... 1 mpg more than the Equinox, and my Aura already had a higher MPG rating than the 4-cyl Accord, Camry, and Fusion! It makes me wonder what kind of mileage my Aura could have gotten if GM had been nice enough to give the Aura/Malibu ecotec direct injection. They didn't even add it for 2010 which is just crazy IMO because assuming DI would bump the econ of those cars to 36-37mpg highway... what a way to stomp Honda and Toyota right into the ground.
Old Jul 19, 2009 | 04:19 PM
95 Z/28 LT1's Avatar
Super Moderator
Saw this in the OP but it wasn't bolded:
"Neither of the Japanese-branded cars came close to Equinox in power output or fuel consumption, neither offers a six-speed transmission, nor – standard sunroofs apart – anywhere near the equipment level of Equinox."
Old Jul 19, 2009 | 04:50 PM
onebadponcho's Avatar
http://www.leftlanenews.com/chevrolet-equinox.html
I hat to break it to you, but the numbers here don't seem to compare that well with a RAV4.
Old Jul 19, 2009 | 04:59 PM
Threxx's Avatar
What are you talking about?
Equinox FWD 4-cyl is rated at 22/33. Rav4 FWD 4-cyl is rated at 22/28.
And that's despite the fact that the Equinox is slightly more powerful, 400 pounds heavier, 6 inches longer, 1 inch wider, and by all reviews so far, a significantly more comfortable ride, too.
Old Jul 19, 2009 | 05:04 PM
.....and the numbers for the 6 cylinder engine?
cricket
cricket
Old Jul 19, 2009 | 05:21 PM
Threxx's Avatar
cricket
cricket
.....and what percentage of buyers who list fuel economy as a major factor/priority do you think will be shopping for a V6 cute-ute in the first place? It'd be nice if the V6 Equinox didn't average 2 mpg worse than the Rav4 V6, but in reality when you're talking about fuel economy wars, the 4-cylinders is what everyone focuses on, and rightfully so. When's the last time you heard somebody compared Honda Accord V6 to Camry V6 in terms of fuel economy? It happens, but not very often.
chirp
chirp
Old Jul 19, 2009 | 08:12 PM
formula79's Avatar
This is a pretty odd, lame quote...
Old Jul 19, 2009 | 09:22 PM
chirp
chirp
Yeah man, I can buy that. I'm just saying that you probably won't see Howie Long doing commercials for the Equinox anytime soon.
My GF just bought a 2009 RAV4 V6/4WD in January. She was shopping between the RAV4, CRV, and the Subaru Forrester and had to have the 4WD. Anyway, I steered her toward the V6 RAV4 because it only gave up 1mpg to the I4 (in "real world" testing) in spite of having over 100 more HP.
I don't understand why GM didn't put the DI 3.6L in the Equinox; it would've been a much better choice for that size of vehicle IMO.
Old Jul 19, 2009 | 09:25 PM
Z28Wilson's Avatar
They're already touting Equinox's 32 mpg highway and "600 mile range" on TV ads and in print. It won't be long before Howie does the same I'm sure....
Old Jul 19, 2009 | 09:26 PM
Z28Wilson's Avatar
No kidding. Obviously someone who has never lived through a northern/midwestern winter.
