Weld in SLP bolt in SFC? Why?
I see it reccomended in here fairly frequently to get bolt in SLP subframes and then weld them in, why is this?
Also how would you go about welding them? At the plates? athe plates and bolts?
how close do they sit to the rockers? would you need to C channel them to weld the to the rockers or can you just weld the straight over by bending the tab?
Heh, my bad
Sounds kind of dumb to get the bolt-ins and then weld them. Once you weld them the bolts become negligible. I'd say get the weld-ins and go. Can't think of any reason to buy the others, unless there is a difference other than the bolt holes? Maybe the bolt-ins are thicker?
Basically it's because some people put the bolt-ins in, let it be for a while to see if they like it. Problem is, some people think it's "good enough" and don't weld them in, and over time they get a little loose.
But yeah, basically so they have they choice, that's why they do it. It's just as good to get weld-ins.
CLEAN
25
Aug 20, 2018 01:31 PM
stockssn2o
May 25, 2015 08:54 AM
