Autocross and Road Racing Technique There is more to life than a straight line
Ultimate Setup???
Old Oct 21, 2003 | 10:27 PM
chpmnsws6's Avatar
Ultimate Setup???
i am tired of not being able to keep up with the porsche's/vettes on the on/off ramps and now its time for me to get my revenge
i've been looking around for a bit now and decided to ask all what is the ultimate setup.
i want to order the nitto 555R2's, 35mm swaybar (front), 24mm rear bar, and a strut tower brace.
what else should i go for?
Old Oct 22, 2003 | 12:38 AM
LPEdave's Avatar
Re: Ultimate Setup???
A vette?
Okay, seriously.... your best bet is a set of Kumho Victoracers. IMHO.
Dave
Old Oct 22, 2003 | 07:24 AM
steve-d's Avatar
What specifically do you want to do?
Speed or handling or both? Meerly increasing the ability to take corners on a ramp or on a track won't get you in the same range as those cars. They have the power:weight ratio well in their favor.
Don't get me wrong, there's much to be gained w/suspension mods, but how much of an increase in speed are you looking to get? If its in the neigborhood of the ZO6/911 crowd, you'll need a generous bump in hp/torque. Otherwise you're just kidding yourself and wasting time.
Suspension:
*Springs, straight rate similar to 1LE
*Shocks, at least Bilstein
**Ultimate combination is to get coil overs from LG Motorsports.
*Rod end LCAs; stay away from Poly (red stuff)
*Rod end PHB
*Front & Rear ASB such as 32mm to 35mm for front and increase for back
*Torque arm. I like the LG TA.
Rear Gears: for street use go w/3:72 or 4:11. Strict track use stay w/3:42.
Brakes:
Get better brakes and larger rotors. Porsche or Wilwood or Bob Bishop C5 or Baer GT+ or better. Do a search for what you want and can afford.
Stiffners:
*STB and SFC (get the three point SFCs)
*DSSL--yes they contribute to a stiffer setup
Engine: How deep is your wallet? Cam only or Heads & cam? You can get into the 410++ RWHP range w/both heads and cam and the necessary bolt-on parts. Find a good tuner. Without this step you'll never achieve your goal. Just sell your car and get a used ZO6.
Exhaust: headers + free flow exhaust. A good choice is the SLP two on the left.
Bolt on parts: CAI, 85mm MAF, 160* stat, light weight flywheel (and while you're there you might as well get a new clutch and PP.)
I think that'll allow you to feel more than comfortable w/those super cars. You can now realize why they cost the numbers they do. I pulled a 911 turbo recently. Felt good.
Regards
Steve
Old Oct 22, 2003 | 08:14 AM
chpmnsws6's Avatar
so far i have LT's,ORYP, catback, lid, gutted ram air with ramair kit, ported TB, removed AIR and EGR
all on an 00 ws6 M6
will be doing a cam soon (this winter)
Old Oct 22, 2003 | 08:16 AM
chpmnsws6's Avatar
along with ported and milled stock heads and looking to spin around 6700-7000rpm
(all this was intended for the strip untill i started having fun turning)
Old Oct 22, 2003 | 10:00 AM
bruecksteve's Avatar
Ahhh, suspension stuff will get you in the same range as those cars on a ramp. Especially if you can drive!
Call Sam Strano... www.stranoparts.com
Old Nov 1, 2003 | 11:49 PM
chpmnsws6's Avatar
how about alot more cubes?
since ill be playing on the highway mainly will i still need a 12 bolt rear?
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Aug 21, 2015 07:20 PM
