For those of you with KYB adjustable shocks
With adjusting them is the number 8 setting the stiffest(sp?) or the loosest(sp?) setting. Its been a long time since I have needed to adjust them. I'm not sure if they even make a difference(not very happy with them)
How do you guys set them up for drag racing, if and when you go?
Thanks.
Dan
Thanks.
Dan
Re: For those of you with KYB adjustable shocks
8 is the stiffest setting.
You may have better luck getting an answer in the Drag Racing forum. Most of the Autox/RR people use Koni, Bilstein, or a combination of the two.
You could also try a search for drag racing shocks and set yours similar. I've seen posts saying fronts at 1, and the rears from 6-8.
Experiment, enjoy! Post results...
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
